Tire size difference help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, May 5, 2018.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    I've been looking a chart with no luck ..my truck was spec with 12r.22.5 kinda odd size to find sometimes someone put 315/80/22.5 who've I'm told is very close in size..tire rubs a little in good turn ..so I'm thinking maybe 11r.24.5 are they close in size ..would that tire 24.5 hurt me in fuel or speed..
    2000 mack dump truck
  3. Lav-25
    Lav-25 Medium Load Member
    535
    807
    Mar 31, 2018
    Rim size is inside diameter of the tire - 22.5 vs 24.5 the rest is basically width and thickness and height of rubber of side wall and casing. 22.5 is two sizes smaller than a 24.5, so putting on 24.5 proablywon't help
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    315/80R22.5 is roughly an inch wider than the 12R22.5, and requires a 9.00" or 9.75" wide rim. If they are using that, I'm guessing you've got a 9.00" rim, but the 12R22.5 tire can also be mounted on an 8.25" rim. The 11R24.5 is going to be an inch taller, but the same width as your 12R22.5. You gain quite a bit of load rating switching to the 315/80R22.5, and lose a hair switching to the 11R24.5.
    If you're rubbing tires on any hard parts, that's a problem (and will put you OOS). If it only happens when you turn really sharp, adjust the limiting bolts on the steering to keep the tires from rubbing.
    Lav-25 Thanks this.
  5. LoJackDatHo
    LoJackDatHo Medium Load Member
    446
    752
    Jan 26, 2017
    Maybe I’m wrong here but last I knew 22.5 & 24.5 rim sizes are different and not interchangeable
  6. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    The lug bolt pattern is the same. As long as you buy the right rims (hub piloted vs stud piloted) they are interchangeable.
    Oxbow Thanks this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Are stud piloted also called budd wheels
  8. LoJackDatHo
    446
    752
    Jan 26, 2017
    Bolt pattern same yes but you can’t put a 24.5 Tire on a 22.5 rim and vise versa. I thought someone on here was saying you could. Maybe I need to re-read post
    Oxbow Thanks this.
  9. LoJackDatHo
    446
    752
    Jan 26, 2017
    No. Stud pilot means rim is centered on studs, hub pilot is center on hub. Stud pilot is kinda like using Tru-Balance centering sleeves
    Oxbow Thanks this.
  10. earthmover
    563
    20
    Jan 27, 2009
    The tires would be on the back of the truck
  11. AlexanderK
    AlexanderK Light Load Member
    156
    94
    Mar 11, 2017
    Would be there any difference on tire size of flatbed trailer?
    I have 285/75/22.5 that came with it and about to install new set 295/75/22.5 (same as on the truck).
