Tire size compatibility 11r22.5 to 295-75R 22.5
Discussion in 'Trucks [ Eighteen Wheelers ]' started by turboguy, May 1, 2020.
  1. turboguy
    turboguy Light Load Member
    132
    23
    May 16, 2015
    hey guys
    I currently have 11r22.5s and I was wondering if I can swap them to 295-75R 22.5?
    Also does it change my speedometer calibration?
  3. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    Yes, if on tractor you must replace all drive to same size.
    Yes, you will have to reprogram your speedometer due to tire diameter difference.
    turboguy Thanks this.
  4. turboguy
    132
    23
    May 16, 2015
    thank you for the clarification
    So I can keep the steer tires 11R22.5 with only changing the drive tries?
  5. Lyle H
    1,289
    2,931
    Apr 16, 2014
  6. turboguy
    132
    23
    May 16, 2015
    ok cool
    and it wont cause any weird wear problems or anything?
  7. Lyle H
    1,289
    2,931
    Apr 16, 2014
    Not because of the different steer tire size compared to drive tire size.
    Now alignment issues and proper air pressure are a different issue.
  8. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    You could get a slight drive-line vibration. Different sized tires on steer versus drives will change your drive-line angles just slightly. Most likely won't be an issue but could be
