Tire Rack Under Trailer or Not?
Discussion in 'Ask An Owner Operator' started by PE_T, Sep 21, 2018.
  1. PE_T
    PE_T Road Train Member
    So, is it worth buying a tire rack to keep spare tires, or should I just rely on buying used tires or cheap new tires whenever a tire blows up?
    Oldironfan Thanks this.
  3. 86scotty
    86scotty Road Train Member
    4,896
    13,572
    Aug 27, 2017
    Appalachia
    Depends on whether you want to pay double. Having a spare tire is kind of a good idea, as history has proven with cars. Keep a spare on your back catwalk or on a trailer rack if you own your trailer. Most keep a spare steer tire which can be used on the steers or trailer.
  4. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    It’s nice to have your own. Especially if you run 24.5’s. I keep a steer and a trailer tire. Look at your cross members and frame, you might be able to wedge one up there and strap it down.
    Rideandrepair, Oldironfan and PE_T Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,015
    42,143
    Mar 5, 2016
    White County, Arkansas
    I would.
    It is always good to have a spare that knows it can fit your tires and that you already bought. SO when it's flat, blown up or otherwise is a problem, anyone with a jack and bolt buster can slap it on. Particularly in a quieter shop that might not have that tire in stock or try to put on something close enough but still a mismatch.
  6. Ridgeline
    22,853
    126,516
    Why don't you stop buying cheap tires and put on some good ones that last.
  7. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    @Ridgeline have the mods change the Road Train Member to Hard Truth Provider
    It comes in handy to have spares until you can back to the barn and put better ones.
    Rideandrepair Thanks this.
  8. PE_T
    Hahaha. I didn’t mean to say I buy cheap tires. I was talking about in a case where you have 8 semi-used (good quality) drive tires and one blows up. If you have no spare, you either buy a used tire or a new cheap trailer tire to match the semi-used tire so as to not spend $500+ on a good quality tire (trailer tire).
  9. Rideandrepair
    17,626
    57,041
    Aug 8, 2015
    I have 2 carriers welded w/ about 8”” Plate steel so I can carry total 4 tires. Been buying good steers for $100- $175. For trailer. Hate to pay top dollar for a tire I don’t really want. Like to keep 2 like tires together on duals .well worth it when needed
    x1Heavy and PE_T Thank this.
  10. TallJoe
    TallJoe Road Train Member
    7,490
    16,275
    Apr 12, 2016
    Chicagoland
    A cheap tire at Love's costs the same as a good tire at a discount store. I want to have the rack too, just need to find time to install it. I'll retire the steers when they get to 6/32 but still plan to use them on my trailer. For the time being they can be both on the rack, waiting for their turn or serve as spares. In worst case scenario, they can also be mounted temporarily as drives too, if one is damaged. I mean, I'll do anything to avoid buying tires at truck stops.
    86scotty, PE_T and Rideandrepair Thank this.
  11. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I pointed out lack of spare with first company I hauled into USA. Owner told me it would just get stolen. That was 30 years ago
    PE_T Thanks this.
