Tire question
Discussion in 'Ask An Owner Operator' started by terrys379, Feb 15, 2014.
  1. terrys379
    terrys379 Bobtail Member
    4
    I need new drive tires has anyone run firestone fd691 or fd695? Are Firestone truck tires any good?
  3. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I've never been happy with Firestone. I had to buy some once as it was the only steer the had in lp24.5. They didn't last but 80,000 miles. I put Goodyear G572 on the drives a couple years ago when they first came out. 180,000 miles and I still have over 20/32" on all 8. I'd highly recommend them.
  4. terrys379
    4
    Thanks I'll have to check those out. Any more input on which tires to buy?
  5. Dale thompson
    5,100
    42,199
    Nov 20, 2013
    commerce twp,mi
    had firestones in the late 70s had serious issues never even looked at them since
  6. Harley Charlie
    Harley Charlie Light Load Member
    131
    127
    Sep 17, 2008
    Warfordsburg,Pa.
    If you want a drive tire that will wear like iron try the BF Goodrich DR244 or 444 I cant remember which but Kevin R will cry about the rolling resistance.
  7. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    Not the most fuel efficient but the general d660 are some good tires. Take a look at the bf Goodrich also. Don't know the number off the top of my head. If you can afford them michilen has some of the most fuel efficient tires
  8. Gliderpilot
    Gliderpilot Bobtail Member
    32
    4
    Jun 13, 2013
    New Jersey
    I just put a set of Triangle Brand tires(24.5 Low pros) All the way around 35k miles ago. No complaints so far and they are get the snot beatin out of them here in the North East Pot holes and all.Traction is outstanding in the rain and snow.Virgin rubber $285.00 Each .The drives are doing quite well but I may switch to Good Year next round on the fronts only.We'll see what happens.
    check out Triangle group dot com.
    GP
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I'm running 695's now and they are good in the snow and are smartway branded. I wasn't a firestone guy before because of a bad experience with steers back in the early 90s but I ran 690's for drives and they wore even and got decent life out of them so I went for the 695's. I tried 663's back in 03 but found them slippery at low speeds and on ice plus they were noisy on wet roads.
  10. terrys379
    4
    Thank everyone for the info I went with bs 726
  11. Pcpirate
    Pcpirate Bobtail Member
    26
    11
    Mar 18, 2013
    I also ran a couple of sets of fs663 on my drives. It was a good tire, other than only being able to get around 55,000 - 60,000 miles out of them. They wear out fast. I mount, rotate and check pressures myself, regularly! I would not recomend them.
