Do you guys air your tires up when it's cold? I checked pressures today and they where all consistently 6-8 lbs lower when it was 42 this morning, it still gets up to the mid 70s during the day. Would you air then back to 105 when it's cold or?
Tire pressure when it's cold
Discussion in 'Ask An Owner Operator' started by 7.3 cowboy, Oct 10, 2013.
Page 1 of 9
Rule of thumb is 1 PSI for every 10 degrees. It's bang on but not linear.
Every manufacturer says a cold tire is one that has sat for at least 4 hours or driven less than 1 mile.
I hope you're using the same gauge to compare. -
Yeah, check air when tire is cold. Hot weather increases air pressure. Look on the tire, it even says check when cold.
IIRC, 70 degrees is the start point for inflating tires. That comes from the maintenance council.
Thus why it cracks me up when Speedco etc ask if I want my tires checked when I pull in the building, right after running 300 miles at highway speeds with 39,000 on my drives...........Useless.
MartinFreightlinerbob and Cetane+ Thank this. -
Air up your tires when they're cold before you start to the cold pressure you're using. Doesn't matter whether its 70, 90 or -10. That's your starting point for the days ambient conditions. Going from warm weather to a much colder morning will guarantee you need to get out there and air 'em up.
Like leftlane says check 'em cold at 70°. If it gets colder outside no matter since 99% of you truckers over-inflate your tires anyway. Some to get better fuel mileage, some because they don't realize the max pressure on the sidewall is for max load and not legal load, and some just because it feels good.
Check tire mfr's load/inflation tables to see what you really need.rollin coal and Freightlinerbob Thank this. -
I believe that settles it. You'd be well advised to put some air in those tires when the temperature drops. -
A solo driver would take a 10 hour break between Miami and North Dakota. That means a proper pre-trip inspection after the 10 hour break and correcting air pressure if needed. You folks sometimes tend to over-analyze and over-complicate the simple. Check and adjust daily if necessary. Correct air pressure is load/weight dependant are you sure 86psi is underinflated in every scenario?
Cetane+ and leftlanetruckin Thank this. -
I'll check the DOT inspection procedure, and post back on that tomorrow. I believe they consider anything below 80 pounds on a class 8 truck to be underinflated. But yeah, you'd have to check the tech data on your tires. OTOH, that's only if you run your tires at that sort of a really low pressure, IMO. -
DO any of you have experience with the self inflating / regulating kits they make now?
Page 1 of 9
