Tire pressure in excessive heat
Discussion in 'Experienced Truckers' Advice' started by Pam in MN, Jul 27, 2019.
  1. Pam in MN
    Pam in MN Bobtail Member
    43
    41
    Mar 15, 2017
    Running in AZ, we started out the day with our steers at 105 psi and when we stopped for our break, we checked them again and the gauge was pegged at 125+. We let a little air out to 115 to compensate for the heat and headed back out on the road. Is this a bad idea? The last thing we want is a steer blowout! We never run in these SW temps of 100+ degrees. Normally run in the North/Midwest and not usually a concern. We plan to check again in the AM before we head out again to make sure we’re not under inflated. I’ve searched for an answer to this and many have said not to let air out, but when you’re running in these temps it’s a little concerning when the gauge pegs out and you’re seeing blown tires left and right down here. Also, there is no real consensus that I’ve found. Experienced trucker replies would be greatly appreciated! Thank you
    tscottme and Trucker61016 Thank this.
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Never let air out if a hot tire. Check pressure after they cool down like after a 10 hour break.....
    I do keep the speeds down a little in really hot weather....
  4. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Agreed, you check your tire pressure out here in the west, before it gets hot. I run at 100 psi 50 to 80 degrees, It allows for heat expansion. I also use a FLIR type temp gauge to check tires when I stop looking for the one that does not match the rest, looking for a low pressure tire as a rule. also good for checking brakes.
  5. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Most of the gators your seeing are from trailers and drives very seldom from steers, get them when there cold set them somewhere between 100 and 110 this time of years. Slow your speeds down to you know something reasonable depending on your load 55 to 60 if its over 100 degrees.
    Lepton1, FlaSwampRat and Pam in MN Thank this.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Most of the gators you see are from not running enough air pressure in recaps, keep em aired up tight.
    tscottme, PE_T, Powder Joints and 3 others Thank this.
  7. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Your right soft tire are a bigger issue than anything else,,, When i drove powder we'd blow off the trailers in the summer sometime 2 at a time. Had one trip tp Vegas where I had lost a outside rear top of Mountain Pass heading toward statewine, by the time I got parked in Whiskey Petes I needs 4 Tires on the trailer. One of those 104 + degree days coming out of Death Valley.
    We'd generally blow off the cap, not the casing but if you kept driving it would take the casing too.
  8. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    as said above never let air out of a hot tire. most of the tires you see blowen is recaps. when it's too hot I try to run at night .it's a lot easer on equip.
  9. Pam in MN
    43
    41
    Mar 15, 2017
    Yeah we’re running at about 60mph. All of our tires are virgin rubber. It’s hot as hades though right now. We thought about only running at night too. It’s tough when on a team run though. Gotta keep moving. :(
    FlaSwampRat Thanks this.
  10. Brandt
    Brandt Road Train Member
    4,405
    5,939
    Sep 17, 2012
    The tires can take the heat and the pressure. The more air pressure the better ! The tire heat up when the sidewalks flex. So less pressure more sidewall flexing means more heat. The tire can take more pressure then the rims. If you listen to satellite radio their is a tire guy that has 30 years experience and he says the tire won't blow out till like 400psi. The rims are rated for like 120psi cold. He says the pressure on steer tire is the minimum to carry the weight rating on side wall. Not the maximum the tire can hold. So letting air out makes even more heat. He tell people to run the tires 10 psi over the what's on the tire because when you hit the brakes the tire shape changes and that part of reason for uneven steer tire wear.
    ChevyCam, roshea, dunchues and 3 others Thank this.
  11. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    I run to Phoenix, AZ a few times a week for over fifteen years with my tires inflated to 110 psi cold and have never had a problem in the heat.
    Your tires are engineered to run in all types of weather conditions so keep your tires inflated to the recommended air pressure regardless of the outside temperature.
    Also the number one reason of tire failure regardless of the tire being a virgin or a cap, is under inflated tires.
    roshea, dunchues, D.Tibbitt and 7 others Thank this.
