Tire pressure dual drive tires
Discussion in 'Ask An Owner Operator' started by istumped, May 6, 2023.
  1. istumped
    istumped Medium Load Member
    507
    243
    Feb 8, 2015
    Yes I know sounds like a dumb question. However what are you o/o doing for tire pressure on for example drive duals? 105,110,120? Or do you go by what the sidewall says? If it matters we have Goodride CM983 22.5 talls load range H 16 ply. Sidewall says 123 psi. Seems high if you ask me? Thanks
  3. istumped
    507
    243
    Feb 8, 2015
    Title should say tire pressure dual drive tires
  4. Big Road Skateboard
    7,860
    45,732
    May 2, 2021
    For Goodride the only safe tire pressure is 0.....
    I'd run 105 summertime
    Diesel Dave and RedForeman Thank this.
  5. lester
    2,959
    8,099
    Jan 2, 2012
    NW, Iowa
    I run what the tire says.
  6. Concorde
    Concorde Road Train Member
    5,918
    21,105
    Jun 29, 2016
    West Melbourne Florida
    I go by what is recommended from the truck manufacturer..it’s listed on the door jamb.
    My steers are set at 120 and my drives 95
    Siinman Thanks this.
  7. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I wouldn’t go by the manufacturer of the vehicle. For example on my trailer to get the max weight the vin plaque says tires need to be 125 psi. Which is ridiculous. Your truck could be set up for a 40k or higher tandems so what’s printed in the door jam is to haul that max weight. However it’s pointless as you probably only haul 34k on it.
    Every vehicle is a bit different. For me I do 105 trailer (low pro 22.5) spread axle flatbed. If I was a dry van I would do maybe 95.
    My steers I do 105 psi as they are 11r24.5 and that’s what they are rated at. If I had a low pro 22.5 I would do 110.
    For truck I run a beefy 16 ply 11r24.5 tire and to get the max rating it can be aired to 125 psi. I run it at 80 psi. According to the Michelin chart I can still maintain over 34k on the drives even at 70 psi. I started at 95 psi and I ended up at 80 psi by hauling 34k on the drives and seeing how the tire sits. Anything higher than 80 psi only the center 4” of tread was touching pavement.
    krupa530 and Concorde Thank this.
  8. kemosabi49
    11,123
    48,871
    Jan 13, 2013
    SW Arkansas
    Fixed it for you
  9. D.Tibbitt
    161,002
    I run everything at 100 psi
    fuller, Cattleman84 and DUNE-T Thank this.
  10. Siinman
    Siinman Road Train Member
    5,655
    14,452
    Mar 5, 2017
    Kansas City, MO.
    Driver tires have been 110-115 for me.
  11. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,983
    Nov 1, 2017
    The Sticks, Idaho
    Not an O/O, but...
    I run 95-100 in my steers and 100-110 everywhere else, reguardless of what I'm under. Never had an issue with tire wear or ride due to air pressure in those ranges.
    Diesel Dave Thanks this.
