Any one here use the fluid to balance tires?
I have it in my steers and it seems to work very well, wondering if i should run it in my drivers?
tire balance fluid ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 2hellandback, Apr 16, 2009.
I have never heard of fluid, are you sure it isn't balancing beads? I run beads in my steers and prefer them to weights.
I use it in my steer tires as well.Works really good.I've also thought about using it in the drive tires,at least the outer four
Have been using a product called Ride On in all my tires for a couple of years. Balances the tires and will seal up a hole up to 1/4 inch in case you a prone to picking up nails or bolts. Washes out with plain water if you dismount the tire getting rid of it. Is charged by the ounce so depending on tire size will be around $20 per.
we use airsoft bb's all the time in large off-road tires
this site gives amounts for thier product, but you use the same amount when you use the bb's
http://www.innovativebalancing.com/tirechartmap.htm
