Tire advice
Discussion in 'Ask An Owner Operator' started by Bluemountainstrucking, Sep 11, 2022.
  1. Bluemountainstrucking
    Bluemountainstrucking Bobtail Member
    TA in Tonopah,AZ on the I-10 is trying to tell me that that a Michelin 275/80R 22.5 and Ironman 295/75R 22.5 are compatible and it’s ok to run with one of each on your steers! They’re whack right?! I run Michelins on my steers but all they had was a the wrong size Ironman when I picked up a screw. Help me out here! Am I crazy to go off on this idiot?
  3. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Math says
    275/80r22.5 39.79" tall
    295/75r22.5 39.89" tall
    With that said, I still wouldn't want to run it.
    I'd assume little harm will come of it.? Depending how bad I wanted to keep moving, I might run it to the house, or down the road to a shop with a match for the Michelin..
    Coffey and blairandgretchen Thank this.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I have no idea but other than a slight size difference is it ok to run two different brands on the steers?
    Would they perform the same as in would or could one brand grab differently than the other which in turn could cause a bigger issue in an emergency or hard stop??
    Coffey and singlescrewshaker Thank this.
  5. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    It'll get yoy on the road till you can replace it, or you could run it out. People do it all the time.
    I'd put another Michelin on though
  6. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Why not plug /patch the tire with the screw or put a used steer on the truck and get to a tire shop that has what you want.
    I doubt you will match your existing good steer with identical wear.
    When I have a tire problem on the road, I use the cheapest option to get home.
    I always change my steers in pairs, when I can get home to my local supplier.
    Your situation above. If buying a new tire is the only option. I would run until I got home and change both. Everyone can use a good spare.
    In my early years I would mix and match sizes and brands to keep my truck rolling. Now I have the option to do what I do.
    Nothing wrong with what the TA tech said.
    Good luck
    Bigtruckdrivah Thanks this.
  7. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    That's fine. Sizes are the same.
    Different brands. But if you have to move it gets the job done.
  8. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    Nothing like getting a big ### ticket, and anything else that comes with smashing a huge safety rating slash.
    Can't pulg a steer. Can't patch a steer.
    Worst ####ing thing in the world is losing a $700 tire to a nail, right after getting reamed by a dot cop named sue.
    Chieftains Thanks this.
  9. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    Since they are steers, it's a bit different than the drives or tandem tires. Many truck stop shops simply won't plug a steer and put it back on. Right or wrong, they usually won't do it on a steer.
    I'd personally be very leery about running 2 different, unmatched, tires on the steers. If that's the only option, I'd only do it until I could get a matched set. Matched set being 2 tires of the same brand, size and model and close to the same wear.
  10. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    During hard times way back, I’ve had a front steer plug and patch. I got the life out of that particular tire without any issues. Today, if it would happened again, I would buy 2 brand new steers. But in an emergency on the road, I would probably have it patch just to get home.
    Btw, you couldn’t give me an Ironman tire to run.
  11. scoobertdoo
    1,512
    2,601
    Nov 11, 2020
    I bet we all could. I'm sure there was one accident that made news that ended a perfectly safe practice back when cars burned Ethel.
    Diesel Dave Thanks this.
