Tire Advice - Best Quality 11R22.5 Tires?
Discussion in 'Ask An Owner Operator' started by DaltonR121, Jul 25, 2013.
  1. DaltonR121
    DaltonR121 Bobtail Member
    43
    6
    Mar 19, 2011
    Masontown, WV
    So I was wondering if I could get some input on 11R22.5 tires. I figured now would be a great time to buy a set of tires before the prices hike up even higher. I would rather go with quality over price. I'm a firm believer in spending money on quality and it saving you more in the long run.
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I'd honestly recommend Michelin supper singles. The math just works. Depending on your current MPG, you will save at least 6,000/year in fuel. Even if they fail before 300,000 miles, you can buy a new set just on the fuel savings. Its like never needing to buy tires again because the fuel savings pays for the tires. I'd recommend the X ONE® LINE™ ENERGY D. That is the most fuel efficient tire on the road right now. For your trailer, the X One® XTA® is the best. For steers, XZA2® ENERGY will do the best.
    Cons on singles:
    Harder to limp if you blow out
    More expensive to replace then single blow out. (although in many cases, tread mismatch is to much and you need to replace both anyway)
    Less performance in deep snow.
    More sensitive to improper inflation.
    Pro on Singles:
    Save at least 6000 per year
    Better performance in deep snow, rain, and ice.
    Half the tires to check air pressure.
  4. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Im assuming your longhaul, those tires wont hold up if you do a lot of off roading
  5. claw444
    claw444 Bobtail Member
    49
    16
    Mar 20, 2013
    I suggest low pro 295/75/22.5 yokohama RY617 on all ten positions... This helps with ride, mpg, and tire life... This option allows you to rotate all ten tires.. Obviously this is not ideal for all applications.. If you are running in deep snow or mud then a low rolling resistance lug tire for the drives from Michelin is a good choice.. Super single tires balloon up like a dragster tire in high heat.. This makes handling bad, wears the centers, and increases the chance of a blow out.. Blow a super single and you are sitting for a long time..
  6. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    Don't buy Dunlap's for drive tires. I had 1 blow up, see another that's separating on side. The tire guy that come to replace my blow up, said they see Dunlap's blowing side walls more than other brand. I've never had problems with Firestones.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    First off, almost all tire dealers now stock singles. Secondly, I've driven in texas in 115 degree heat my singles were fine. They were slightly over inflated, but not more then duals. Maybe a few psi. I now run nitrogen in all my tires to avoid temperature induced over and under inflate. Of course on the road i can fill um with air if i need to.
  8. DaltonR121
    43
    6
    Mar 19, 2011
    Masontown, WV
    I'm not sure how I feel about super singles just yet. I haven't ever ran them so maybe I'm just afraid of what I'm not used to hah. We do a lot of work for the coal mines though and my biggest fear is blowing one. We're in very tight places often and our tires tend to pick things up more often than I'd like. I had to patch a drive tire last week that had a good size bolt in it.
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Top 2 brands are Michelin and Bridgestone. I signed up for the Michelin Advantage program. Saves about $90 over retail off a 11R24.5 I just checked on yesterday. 28% off the retreads.
    I'm a cheapskate but I swear by my Michelins.
    DaltonR121 Thanks this.
  10. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Dont buy retreads through advantage way cheaper to buy them direct from ozark or allied between 210 and 260 depending on cure. Process custom or premold and with casing credit drops another 60 off the price
  11. craggy1982
    craggy1982 Light Load Member
    205
    386
    Apr 21, 2012
    KY
    I would not run super singles especially if you are pulling a dump. I drove for R and J for 7 years and they were always trying to save money and they ran them super singles for awhile and they quit because they was replacing them every time you turned around. if a super single blows while you at a delivery you cant dump the load. I know its not ideal with duals either but if careful you still can. also if its hot and your bed in the air and that super single decided to blow over you go. also when you are in rural areas super singles are extremely difficult to buy. seen them more than once have to buy two tires and rims to put on truck so they can get truck back to the yard. when I bought my truck I said never will I run recaps or super singles.
