Tips or picks for securing utility trailers to flatbed
Discussion in 'Flatbed Trucking Forum' started by SIGNATURE.SIV, Mar 19, 2019.
  1. SIGNATURE.SIV
    SIGNATURE.SIV Bobtail Member
    Supposed to load some of those little cargo tongue trailers but dont have chains only straps.
    Any tips or pics on how to properly secure them to a flatbed with straps?
  3. TripleSix
    127,946
    Multiple stops, big stacks of them with styrofoam blocks between them?
    The load is going to sway. If you have straps with J hooks, strap the hook to the top trailer of each stack and cinch it down evenly 4 points securement on each top trailer of each stack. Be sure to check it periodically.
  4. SIGNATURE.SIV
    Its supposedly the cargo style covered units. I'm assuming I'll have to strap the axles and tongue's down
  5. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I would throw one over the top to keep it from going side to side, and criss-cross over axles and springs.
  6. cke
    cke Road Train Member
    5,857
    71,782
    Aug 4, 2013
    Colfax Wi
    2 over each axel and one over the tongue. Block the wheels front and back. Should be good
  7. HillbillyDeluxeTruck
    5,878
    29,938
    Mar 3, 2013
    San Antone
    How about get some chains/binders so you have the proper securement for the load?
    D.Tibbitt and Razororange Thank this.
  8. HighwaySuperTramp
    HighwaySuperTramp Medium Load Member
    316
    349
    Feb 8, 2015
    That would be my go to. Nail some 2x4's down to block the tires, run a chain over the axle and bind it down, then a rubber pad under the dolly leg and strap the tongue down.
  9. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Most places I have trailers loaded. They won't allow chains. But they have secured with 2x4's, wood blocks and styrofoam blocks as needed.
    I have chained thru the stake pockets to secure after leaving loading site.
