Tilt steering
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sledneck1639, Jan 31, 2014.
  1. sledneck1639
    sledneck1639 Bobtail Member
    28
    Nov 23, 2013
    MN
    Has anyone ever put a tilt wheel steering column in an old fixed column truck?
    If so was it an easy transplant or a bunch of screwing around fabricating?
    My truck is an 88 FLD with a 22" wheel and i bust my knuckles on the windshield from time to time.:biggrin_25512:
  3. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have in my 85 359, the column out of the early 379 would bolt right up. It was tough finding an 88-93 with tilt that was in good shape thou. As for your freightliner I'm sure some thing similar would work but don't know what combination exactly good luck.
    sledneck1639 Thanks this.
  4. sledneck1639
    28
    Nov 23, 2013
    MN
    Thanks, it's good to know at least it can be done. I might check out some older cabovers. Their columns came straight up out of the floor almost, i assume they offered tilt as an option.
  5. wore out
    15,319
    184,959
    Jun 5, 2013
    You know that isn't a bad idea. I bought an older cab over freight liner cause it had a sweet 3406b in it. Drove it home it has tilt and telescope wheel. I was shocked actually it's around early 90's or so. I have heard that later columns can be used with a little modification, but haven't done it myself. It's well worth the effort though.
  6. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Nothing is impossible. It only takes a vivid imagination and deep pockets. The best tilt and telescopic system I ever used was in a GMC Astro with the sierra interior. It was one of the later model years because it had the big grille. As I recall the whole column moved toward the driver. For me it resulted in a much more effective tilt.
  7. fld
    fld Medium Load Member
    383
    258
    Nov 24, 2012
    The freightliner tilt wheel is a little bit different than the regular column. It requires not just the column, but the brace that holds the column.
    I bought one thinking thinking that I could just swap the columns, but they mount differently. Then I bought another tractor that had a tilt wheel in it.
    Freightliner parts are generally interchangeable, but I'm not sure that the cabover uses the same setup; it may but I wouldn't gamble.
    My advice is to find a conventional at a scrapyard, and take the column and the brace. That way it will be in the right spot like it's supposed to be from the
    Factory, and you will have the right mounts, etc.
    And let me tell you, if you have never driven a Freightliner with a tilt wheel, you can't imagine what you are missing. Of all the trucks that I have driven, that tilt wheel gives you the greatest range of adjustment of ANY truck. It will feel like a different truck to you. It was one of the most brilliant things that Freightliner ever did.
    Whatever it costs you, you will never, ever regret it.
  8. sledneck1639
    28
    Nov 23, 2013
    MN
    Yesterday i went crawling around a truck graveyard here in Bemidji, walking in about 3 feet of snow. I found a 94 conventional, and looking at it, like fld said it does look like it has some different mounts.
    I can make it work with no problems im sure. The only thing is that first joint in the shaft down by the pedals will have to be in the exact same location i.e. distance from the firewall for it to work.
    Where is a good place to get new steering wheels on the web? The one in that truck has seen better days.
    And as long as im on here does anyone recommend a good dealer for turbos. Im looking to get a new Holset HT3B
    Aaannnddd a new driver's seat to add to the list
  9. fld
    383
    258
    Nov 24, 2012
    There are aftermarket steering wheels available (I think on ebay and other truck shops sell them), but they are expensive and they have what appears to be a hard, wood finish.
    Myself, I think the hard wood is hard on your hands. The original wheel is made of some kind of special rubber type material. It has a hardness to it, but when you grip it, it gives. I have found this to be easy on my hands, very comfortable, and I even feel that I have more control over the truck. It's one more thing that Freightliner really got right on the FLD.
    I would try more scrapyards for a steering wheel and seat.
    If your truck is an FLD model, even though it is an early model, I THINK, that if you get the tilt wheel assembly and you take the steel brace that the assembly bolts up to, everything should bolt in and be in the same spot. The brace bolts up from the firewall to under the dash. The brace itself should bolt up the same; the difference is that it is made to accept the mount for the tilt wheel assembly. If it bolts up the same, everything should line up, including the first joint.
  10. jhainline
    jhainline Bobtail Member
    I know this post is old im trying to do the same to my 84 359 I got a column out a 92 is there any pointers you could give me thanks
