Tightening valve stem tip
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, May 19, 2013.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    While checking over my truck yesterday, my one steer tire was 5 lbs low on air. so I wondered if it was just the temp change or if I had a leak. after checking the other side, I knew I had a small leak. found it around the valve stem where it attaches to the rim. I tightened it up & good to go. today I was thinking I have done this before on my inner trailer tire about 3 months ago, after calling my local shop & them telling me there were no way to tighten without taking outer wheel off. I figured out a way, which may not be new, however I never heard or seen of this before. so since I have a new phone capable of videoing, I would try to make a short video on how this is done. for those who never knew it could be done & save someone some unneeded cost & downtime. it took me 45 min just to figure out getting the video to the computer. :biggrin_25511:so this may be my last video for a while. o.k. I am trying to now figure out how to post video on here?
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I'm a computer nit- wit. But to put a video here ,I think you have to post it on u tube . And then post a link on TTR......
  4. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    In the reply box, is an insert video tab at the top on the right hand side. Though, as Cat sdp mentioned, I also think that you have to post to an image\video hosting site and "copy link: here.
  5. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Could you just say what you did. Had two tires installed last week & left front stem is slightly loose. Really do not want to go back if I can do it at the shop. Thanks...
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I never had a problem getting a valve stem tool to any of my valve stems.
    There's the long one with the red handle and also a stubby about 1/2" long.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    never knew there was a valve stem toll, that could tighten inside wheel valve stem. have any pic's ? name of tool or place to buy ?
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I am talking about tightening the valve stem, not the inner core
  9. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Most of the time its not loose, but rather corroded and ready to fall apart. Especially with aluminum wheels. Tire has to come off.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    http://www.youtube.com/watch?v=lugYWlikuw4
    O.K this is my first video. will do better next time. I have fixed this type leak more times than I can count. after time & bouncing, vibrating, they do come lose, or maybe the rubber seal shrinks. I don't know. this video only shows the valve on the steer tire being fixed but the same technique is used on any tire, any position.. you could also use the 9/16 crow foot & a 3/8 by 1/4 reducer & then use 1/4 socket & extensions if needed to give you more flexibility. I have always used the 3/8, but I have used 3 swivels before too. I have all steel rims. other type rims may be different & may need other methods. this is just something I taught myself & hope it can help someone, or they can tell some one & help someone.
