Tie-Down Straps and Anchor Points
Discussion in 'Flatbed Trucking Forum' started by Bay, Jul 21, 2017.
  1. Bay
    Bay Bobtail Member
    15
    Dec 3, 2015
    Hey y'all
    I'm looking into going solo flatbed and wondering about the many tiedowns available. The only straps I can properly understand (chain is good) are the flat hooks, which go to trailer frame or stake pockets, and other hooks which can go to D rings. But why would I get a V ring or looped end and where would I secure them? Even if I have a welded hook, do you twist the loop until it's tight or rely on the winch to pull it secure, and what about the V ring?
    Thanks!
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    The v ring and looped ends go on hooks that are designed for such straps.
    Flat hooks don't go to frame or stake pockets, they go to the rub rail, a lip on the underside of the trailer, or specially designed attachment points on the trailer designed to accept them.
    snowman_w900 and MJ1657 Thank this.
  4. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    I was always partial to the chain ends, but I had longer chains on the strap end to go all the way around the pocket and hook back onto itself.
  5. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    Depends on where it is. I prefer a flat hook on the ratchet half of a ratchet strap. Keeps the body closer to the deck usually and avoids the ratchet scratching paint as you go down the road. I prefer chain ends on straps, the chains allow the straps to go on angles. Flat hooks will to a certain degree but not as much. Plus chain ends can go around stakes and spools, or chain pulls, opens lots of options.
    V hooks are next to useless. Usually the hook won't fit down through the rub rail, unless you smash it with a hammer. Basically turning it into a flat hook.
    The ones with the extra D are for you to hook it back to itself.
    MJ1657 and snowman_w900 Thank this.
  6. kylefitzy
    kylefitzy Road Train Member
    4,724
    19,663
    Aug 12, 2007
    Kansas city,Mo
    V hooks work well in round and triangle shaped cutouts on the sides of the double drop trailers I pull. We usually use them to secure our deck plugs/ filler plates on the return trip and light crates on the way out. Strength is not much of a concern.
    DDlighttruck Thanks this.
  7. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    J-hook tie-plates have the best WLL to tiedown quantity ratio. Most I've seen are rated 6,500 lbs or higher.
    Granted, you'll never find a 4" synthetic strap with a 6,500 lb WLL (most I know of are only 5,400 lbs) but the strength is there.
    My personal choice is the round post with a chain-end strap. The welds go all the way around the post (unlike the stake pocket) and are much less prone to cracking. I'd say, for someone looking to be flexible in the kind of open deck freight they want to carry, stake pockets, posts and a J-hook plate track on either side will give you the most options (J-hook plates for 3/8" chain for equipment and coils) for securement.
  8. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    I've seen 4 inch straps marked for 6600 lbs. Certainly not common, but they are out there.
    Zeviander Thanks this.
  9. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    The v hook straps have 1 good use. To attach too a small shackle on something to small to get a chain through. I have pulled a lot of ac units and transformers this way.
    Bay and kylefitzy Thank this.
  10. Bay
    Bay Bobtail Member
    15
    Dec 3, 2015
    yes I've seen them.
  11. Bay
    Bay Bobtail Member
    15
    Dec 3, 2015
    Thanks for all the info, good fellas. Just still not understanding how to keep a sewn loop end secure - do you tie it around and into itself, or rely on the strength of the winch to keep it tight?
