no codes but when i check the throttle sensor with cat et i have 16% at idel and with motor off and 89% on floor put new sensor on and still the same is there any way to calbrate this 2003 international 9900 with 6nz77988 cat runs ok like it is but maybe it could run better at 100% throttle
throttle sensor problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by little cat 500, Oct 5, 2011.
the last time I solved this problem, it was carpet under pedal)
Ok, check voltage output of gas pedal sensor. Over 4.4V is 100% -
Make sure you put the throttle pedal sensor in that your VIN calls for. Cats need a different throttle pedal than a Cummins.
it's a cat sensor it reads this with the pedal out of the truck to got the sensor from international
There is no adjustment to the throttle position sensors. Your percentage readings do not mean it isn't getting full throttle. If you changed it for a power problem that was the wrong thing. If the TPS goes over 100% for some reason it will shut the fuel off and back on so fasst it will make the truck act like it has a miss.
Mykhailo Thanks this. -
Back when I had a n-14, I had to turn key on with truck not running, push fuel pedal down and release 3 times to calibrate. Not sure if it is the same for cat but it won't cost you anything and let me know if it does work for when I replace mine
tufftimestrucking and dadddymills Thank this. -
no i don't have a power problem it just don't look right on the cat et i was just thinking that if im not getting 100% i might have more power than do now i have mr haney's tune so there is no power problem
i tryed that some body awile back told me to do that it doe's nothing for a cat well not mine anyway's that may be the way to do it but mine don't respond that way
Ouh, I wanna tell you that all new Cat ECMs read 80-90% with pedal to floor and over 80% is a kick down power, so let the truck keep running.
