throttle pedal problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dismag, Jul 20, 2012.
  1. dismag
    dismag Bobtail Member
    37
    Jul 20, 2012
    for last one month i have that problem on my Columbia 2005. The engine starts fine the problem is that throttle pedal doesn't accelerate some time and some times just disappear at the time i am driving. Went to several shops they replace censor, problem disappear for one week and then come back again. So frustrating because I have already spent $$$. Just want to see may be some one here had the same problem. Please let me know or if you have any advices please share with with me. Thank you in advance.
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Wear in the pedal assembly itself causes this problem. The whole pedal assembly needs to be replaced to cure it, not just the sensor.
    dismag Thanks this.
  4. dismag
    37
    Jul 20, 2012
    ok thank you. I will replace it and let you know if it was the cause.
  5. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    It will be the cause.
    dismag Thanks this.
  6. dismag
    37
    Jul 20, 2012
  7. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    before you replace the pedal make sure all the terminals at the batteries are clean and there's good connection, hopefully a loose battery nut will the problem.
    let us know what was it.
  8. dismag
    37
    Jul 20, 2012
    replace pedal same problem
  9. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    wished I would have seen this earlier.
    go get yourself a small volt/ohm multimeter. I got mine from walmart.
    http://www.walmart.com/ip/GE-Analog-Multimeter-14-Range-6-Function-Yellow/17117738
    Use it to test things like your foot pedal BEFORE you replace it.
    You need to use an analog on these because as you press the pedal, it's moving a potentiometer. It's basically a wire wrapped around an insulator core with a copper sweep on it.
    It sits there all day long in the same spot and can wear a dead spot into the resistor side.
    The only way to spot if it's bad is as you are pressing the pedal down with the ohmmeter hooked up, you will see the dead spot as a quick jump in the needle. It will go open and then come right back. Something you will NEVER see with a digital meter.
    You can also use it for testing for bad wiring harnesses and connectors. Same thing. Needle will bounce when it sees a sudden open as you flex wires or move a connector and it comes back.
    nice way to test for intermittent problems.
    DetroitDudeBro Thanks this.
  10. dismag
    37
    Jul 20, 2012
    all of a sudden dash board panel stop working and that throttle pedal not working but engine starts okey.
  11. dismag
    37
    Jul 20, 2012
    I have that code error MID 128 SID 91 FMI 3 Fault 21 what it can be?
