Three-rail vs Two-rail Winter Tire Chains?
Discussion in 'Ask An Owner Operator' started by PE_T, Dec 17, 2018.
  1. PE_T
    PE_T Road Train Member
    I am going to guess the three-rail chains are a bit cheaper and take less time to install, but the three-rails may not last long because they can’t be installed as tight as the two-rails? What do you guys think?
  3. Long FLD
    Long FLD Road Train Member
    11,385
    45,965
    Mar 4, 2015
    Three rail (dual) chains are more expensive because a pair of them covers four tires, not two. And there’s no reason they shouldn’t last as long as other chains. You can get them as tight as you want to get them. So if they don’t last long it’s probably user error.
    stwik, Oxbow, Lepton1 and 1 other person Thank this.
  4. PE_T
    I meant to say a three-rail is cheaper than a set of two-rail, but I don’t know.
  5. REO6205
    REO6205 Road Train Member
    13,172
    60,484
    Feb 15, 2014
    California.
    Read @Long FLD 's post again. He nailed it.
    Oxbow and Lepton1 Thank this.
  6. PE_T
    I made a mistake. I should have said a pair of three-rail is cheaper than two pairs of two-rails.
    Oxbow and Long FLD Thank this.
  7. REO6205
    13,172
    60,484
    Feb 15, 2014
    California.
    Okay. No problem. Three railers are heavy and harder to put on than singles but they give much better traction.
    If you get the kind with cam lock tighteners you can cinch them down as tight as you want.
    Oxbow, SavageMuffin, Lepton1 and 2 others Thank this.
  8. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    What other kind is there? (serious)
    stwik and Oxbow Thank this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    In deep snow the two rail (singles) will still get stuck. The tire with the chain will dig a hole, the other dual will just sit and spin on top of the snow carrying all the weight.
    stwik, Oxbow, PE_T and 1 other person Thank this.
  10. Long FLD
    11,385
    45,965
    Mar 4, 2015
    My chains only had a single cam where you hooked them together, I assume he’s talking about the ones that have additional cam locks around them to take the slack out.
    Oxbow, rank and 25(2)+2 Thank this.
  11. REO6205
    13,172
    60,484
    Feb 15, 2014
    California.
    Serious? The kind without the camloc tighteners. Yeah, they actually made such a thing. I think I started seeing the camlocs about thirty years ago but it might have been less, too.
    We took a whole pile of the old style chains to the scrap yard a couple of years ago. Once the drivers found out how quick and easy the camlocs were they wouldn't use the other kind unless they had to. I don't blame them either. We started phasing out the old style and replacing them with Pewag camlocks.
    . Pewag makes the best chains.
    We kept the old style single chains that weren't worn out and used them for drag chains and for our off road equipment that stays chained up for several weeks at a time.
    Oxbow and rank Thank this.
  12. rank
    9,916
    113,498
    Feb 11, 2010
    How did you get them tight without cams? Don’t tell me bungee cords
