Thread Sealant: Tape or Paste
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Caterpillar Cowboy, Apr 25, 2020.
  1. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Which do you guys prefer and why? The tape style thread sealant or the paste?
  3. Dodsonf855
    Dodsonf855 Bobtail Member
    25
    22
    Mar 15, 2020
    South arkansas
    Depends what I’m doing.. steel or brass to aluminum paste steel to steel tape. Small brass use tape you don’t have to tighten as tight and can unscrew with out rounding hex.
    HopeOverMope Thanks this.
  4. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    I like paste better. Less chance of it getting ripped and sucking into the system.
  5. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,896
    Sep 20, 2015
    Southern Ontario
    I’ve used both. Both work for their intended purposes.
    Sealant is easier to apply. Works well.
    Tape also works well. Sometimes it’s a pain in the butt to get right. I’ve ripped a lot of failed attempts off a roll when it doesn’t go on the threads straight, flat, or it slipped and shrivelled up.
    So far my go to is the hydraulic sealant for ease of use.
    Sometimes for that difficult used thread or a lot of pressure (like hydraulics), the tape is my friend (for that one fitting).
    Also tape can get the fitting snug and not leak when that fitting needs to be in a certain position. Can be a difference between a leak or a snapped fitting just by applying more or less tape for certain thickness.
    Brettj3876, rolls canardly and Doealex Thank this.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,984
    71,268
    Nov 1, 2017
    The Sticks, Idaho
    Depends on application... But I usually fall back on tape. Ive had too many of the pastes fail and leak... Maybe not today or tomorrow, but eventually. With tape I've never had an issue with a leak appearing at a later date once it is applied correctly with no leaks at initial assembly.
    However there are the rare case when paste does seem to work better. Usually when the pieces are made of certain materials... Ex. Stainless steel fittings, plastic fittings, aluminum fittings, or if the product being moved through the pipe is particularly corrosive... Like acids or liquid fertilizer.
  7. 201
    201 Road Train Member
    12,620
    25,902
    Apr 16, 2014
    high plains colorado
    Well, when I think thread sealant, I think Locktite, and no toolbox should be without a tube. For fittings and such, I always used the white tape, if you can figure out which way to wind it around a bolt, that is.
    Cattleman84 Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    My go to on anything with wheels that has a pipe thread joint is.
    White permatex thread sealant with teflon.
    Small bottle last just long enough and is almost gone when its dried out.
    Gave up fumbling with tape years ago and leave it to the plumbers. I also heard from brake engineers its not good for brake valves.
    spsauerland and Doealex Thank this.
  9. Doealex
    597
    1,132
    Feb 21, 2018
    You’re right . Now it is is specifically instructed on many air parts to use liquid thread sealant. I figured the liquid sealant has less chance of getting stuck in lines if it gets sucked in.
    spsauerland and Goodysnap Thank this.
  10. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    My preference is the pipe dope pastes
  11. rolls canardly
    rolls canardly Road Train Member
    1,621
    3,936
    Feb 7, 2009
    mt. pocono. pa.
    Hold the fitting in your right hand.
    Start tape by your chest,
    go down and clockwise away from you.
    Do it the same every time, like 4 or 5 wraps.
    This puts finish end pointing away from thread start direction when you thread it in.
    Good point on the number of wraps can orient pointing fitting to your need.
    I found "blue glue" in everything I ever took apart; but I guess that ain't good in brakes.
    I don't use paste on anything; to me it's an obsolete technology.
    Like cast iron sewer pipes, oakite, and poured lead. Then do same job in PVC pipe. See?
    Faster, lighter, just as strong, and I think more sanitary. I don't even own any paste.
    Paste also recommended in household gas fittings, like for stoves and water heaters.
    Both of which I don't own, either. Stove, electric. Hot water, furnace coil.
    It's raining and all the dogs are even asleep. You should be too, by now.
    D.Tibbitt Thanks this.
