Thread sealant for wet kit
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by muthertrucker210, Apr 5, 2018.
  1. muthertrucker210
    muthertrucker210 Bobtail Member
    39
    23
    Feb 3, 2016
    Just finished installing my 1st wet kit and hit a snag. On all my connections I used permatex liquid thread sealant. Only had 2 very small leaks on the pressure side at the threaded fittings.
    Should I use a different type of thread sealer for the pressure side?
  3. Old mark
    Old mark Light Load Member
    77
    197
    May 22, 2016
    I use permatex on all pipe thread fittings. JIC fittings dry. No problems on pressure or return side.
  4. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    You should not need thread sealant on hydraulic fittings, they are a tapered seal; if you are using pipe fittings on the pressure side you are asking for trouble as they are not rated for the pressure.
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Pipe fittings are rated for pressure. Quite a few pumps have female pipe fittings for the pressure lines. You probably didn't get an even coat of sealant around the fitting. I like using the heavier natural gas rated tape around pipe fittings. Make sure it is natural gas rated tape as the cheap stuff most places sell is junk.
  6. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    To get to 3000 psi with a 1 inch pipe fitting requires a stainless fitting with a .095 wall thickness, brass fittings will barely get you to 2000 psi, carbon steel and galvanized will contaminate the fluid.
    I always build for 3000 psi because most pumps that find their way onto dump trucks are rated for about that.
    But I have seen guys plumb them with galvanized water pipe, I just shake my head.
  7. AModelCat
    154,240
    Personally, I prefer thread tape to pipe dope on NPT threads. Just don't put the tape on the first thread or 2 as there is a chance the tape could work its way into the system. Also want to wrap the tape the opposite way of how you'd thread the fitting in so that tightening the fitting doesn't peel the tape out.
  8. muthertrucker210
    39
    23
    Feb 3, 2016
    Thanks guys for the info. I think I'm going to try some good tape and see if she leaks. I did use the stainless fittings for my pressure side, they are NPT not JIC type.
    RET423 Thanks this.
