Thoughts on dove tail trailers.
Discussion in 'Flatbed Trucking Forum' started by Hurst, May 27, 2014.
  1. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I'm running a 53' Fontaine step deck. Its an Infinity, Aluminum deck with steel beam frame. The trailer belongs to the company owner. I pay for the usage of it. I like the amount of bed space I have with it. 10' upper and 43' lower deck. I have Superior ramps installed on it and there in is my main focal point of frustration with this trailer.
    I'll haul anything thats paying well and I particularly like hauling equipment but dont want to go with an RGN as I think the set up I have now offers more versatility with various 'legal' loads. I dont want to haul too many heavy permit loads. I dont think the stress on my truck is worth the money.
    Anyway,.. I was looking at Superior trailers website and they had a Doonan (Spelling?) 48' spead axle trailer with a 5' dove tail bolted on the back and 3 ramps that when closed up creates a 53' deck surface. I enjoy the functionality of the Superior ramps on my trailer,.. I just hate dragging them out and setting them up to get a load up on the trailer. I've resorted to pulling the ramps out and laying them on the ground and then pulling the trailer forward to set them up. I was thinking a dove tail with folding ramps at the end of the trailer would be a better solution. I'd still have the usage of 53' with the simplicity of a dove tail.
    Anyone have any experience with this type of set up? How much stress can that 5' hold up? I mean how reliable would it really be? Would it suffer premature cracks in the frame? I'd like to have the best of both worlds.
    Also,..
    I've been considering a Benson all Aluminum trailer if I didnt go with the dove tail. I have an 05 Columbia and with the 53' Fontain step deck I weight 34,400 lbs full of fuel. If I cut fuel down and run half tank I can put 46,600 on my deck and still be legal. How ever I've had a few times where I went over and it was really frustrating tell them to remove some items to get the weight down. If I could knock 1500 - 2000lbs off, I could then run full of fuel with just about any load up to 48k.
    How strong are those Benson aluminum trailers? Or any aluminum step deck compare to one with a steel frame? Is it worth the extra money or would I be looking at a nightmare with constant frame repairs?
    Thanks,
    Hurst
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    Before I started pulling tanks, I was pulling a 48' stepdeck with a dovetail, I don't remember the length of the tail though. Mine was all steel, and had hydraulic ramps powered by an electric over hydraulic motor. The set up worked very well in most cases, only time I had problems was going in and out of some farm driveways. The hoses for the ramps hung about six inches off the road, and would drag in the dirt, and sometimes tearingthe hoses off. We rerouted the hoses after the second time it happened and solved the problem. As far as how strong the tail would be, we never had an issue, but it was a steel trailer. I would think aluminum would be more likely to crack, but I dunno.
    Overall it was a nice setup, I didn't have to lift ramps around, and I could load nearly anything I wanted, though lawnmowers were a pain. I loaded a 963 cat on that trailer many times with no issues, but I think that was about the limit. Hope that helps some
    Hurst Thanks this.
  4. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    We had one on harvest. Low profile vehicles are hard to get loaded but it can be done. My next project trailer will be adding one to a trailer
    Hurst Thanks this.
  5. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    As stated already you have 16' of ramp now, a dovetail will give you a little less than 10' so the angle is going to be greater. Also when loading vehicles, the rear 5' will be unavailable to load vs your setup now. The 16' are a pain in the rear to get setup, and it seems very few people want to pay for that, which is why my ramps went with my trailer when I sold it. They made great stairs to get up the deck though! ;)
    Hurst Thanks this.
  6. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I must be the only person who doesn't think they're a pain in the butt. I think they're too nifty
    Rubber duck kw and Hurst Thank this.
  7. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I think I'm just going to have to look at them in person to really get an idea if they will work for me or not.
    Worst case scenario,.. I go with an all Aluminum 53' Step and have the Superior ramps that I loath so much installed.
    Thanks fellas.
    Hurst
  8. fortycalglock
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I think you use them enough to have value. I bought mine because I saw ambulances I could haul, but as rates in general have gone up, they've gone down. What I ended up finding, at least where I'm at, was I could find normal freight paying the same or better as a ramp load. Of course there were occasional gems, but only one where I couldn't use a rollback to unload. All in, it's safe to say the ramps add about 500 pounds to your empty weight as well. At $50-100 for a rollback, it takes a lot of ramp loads to get ahead.
  9. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I paid for mine going into Florida for $3+ and coming out about $2.25 with UPS trucks back to Sturgis Michigan
  10. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    I agree with Fortycalglock....we have used Landolls before.
    I spec'd out a Wilson 53 beavertail step a few years aago but decided against it because:
    1. extra weight or the ramps and beaver tail section (they really have to throw the steel into that rear section to make it strong enough).
    2. The beaver tail would have pushed the axles too far ahead for my liking.
  11. fortycalglock
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Did you bounce to SC for those trucks???? They used a tow truck to unload me at Sturgis.
