Thinking of doing a rebuild on a DD15? DONT!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 1dan, May 4, 2018.
  1. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    Just don't do it. These engine are like cheap plastic bags that work great until they break and its not worth fixing them, It happened to me and many others i met after I did the rebuild. I wish I knew this before. Just putting this out there, hoping to help some poor people.
  3. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    What are the problems? Parts unavailable? Too expensive?
  4. Dave_in_AZ
    369,846
    I know these dudes that dropped the pick up tube, guess this is pretty common, and spun a main.
    They got it reworked, back in truck, $18K.
    Not long ago. I'm curious to see how long it lasts as well.
    KB3MMX Thanks this.
  5. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    My engine had a rebuild and the main bearings seized after 50k because the crankshaft was bad, and this is a very common problem. Also the O rings from the oil pump tubes can drop lower pressure and if not fixed in time can damage the engine, but that one is and easy fix and many shops will recommend changing it.
  6. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    So you are saying that because you or your shop did not do all needed repairs and upgrades the DD15 is a bad engine?
  7. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    No, i am saying that because the crankshaft is not replaced in a regular rebuild and it might not show signs of damage but it will not last long after that. So your regular rebuild will cost as a new engine if you will have to change the crankshaft as well
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Did you measure the crankshaft to see if it was within tolerance when you did the rebuild?
    Did you replace the bearings?
    Did you replace the oilpump?
  9. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    the bearings and the pump are included in the kit. not sure about measuring it tho
    daf105paccar Thanks this.
  10. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The tech that rebuilt your engine took shortcuts , if he did not check the crank . Would took about 20 min extra .
  11. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Are they not standing behind their work? Sounds like a workmanship problem, not a product problem. If Detroits regularly blew up after 50k, they'd be out of business by now.
