Thermoking SB-210
Discussion in 'Refrigerated Trucking Forum' started by Noel Mederos Alvarez, Nov 4, 2020.
  1. Noel Mederos Alvarez
    Noel Mederos Alvarez Bobtail Member
    7
    Nov 4, 2020
    I have an SB-210 thermoking. When the temperature drops it does not stop at the set point, it continues to drop
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    3 way valve might not be shifting to heat which is likely caused by the pilot solenoid not energizing. Put it on heat see if the coil on the solenoid is magnetized by touching it with a small wrench .
  4. Noel Mederos Alvarez
    7
    Nov 4, 2020
    When the fault occurs, it shows alarm 3 and 203. Where the return air sensor is located?
    Thanks for your help
  5. reeferwrencher
    556
    1,474
    Aug 4, 2018
    It has 2 return air sensors,one is for control and one for display.They are located at the lower passenger side of the reefer in the back.They should have a brass clamp on the top of them.If you change them then you have to calibrate the sensor grades in the controller which you might not want to get into.
    Noel Mederos Alvarez Thanks this.
  6. Noel Mederos Alvarez
    7
    Nov 4, 2020
    I changed the air return sensors but they keep codes 3, 203 and 11.
    Also clean the connectors that go to the micro. When I try to eliminate code 11, which is the only one that allows me to do it, it comes out again.
    Any suggestion
  7. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Yeah you have to go into the guarded access to clear it and and calibrate the sensors try to see if there is a youtube video showing how to do it it's kinda hard to explain on a post
  8. Noel Mederos Alvarez
    7
    Nov 4, 2020
    thank you. I check you tube. When I have the results I will comment, thank you again
    reeferwrencher Thanks this.
  9. Noel Mederos Alvarez
    7
    Nov 4, 2020
    Modify the sensors in the guarded access in addition to eliminating the errors. I start without problems. Thank you very much for the advice
  10. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Sure enough
