Hi all,
I have a Thermo king SB-210 with about 15k hours on it. I was recently driving with my reefer on and when I parked I came outside to an off unit with a message of "Communication failure lost controller connect". I initially was thinking maybe there's a wire that came loose with the rough drive, so I restarted the unit and it was running for about 2 hours with no movement and I got the same message again. Any ideas?
Thanks in advance!
Thermoking SB-210 Communication failure lost controller connect
Discussion in 'Refrigerated Trucking Forum' started by FCBexpress, Jun 10, 2021.
I had one do this last week with 10,000 some engine hrs, I open the relay box door found the inside VERY wet because the black Capplug had fallen out of its hole allowing water to get in from rain or outside trailer washing, I unhooked the battery right away then dried this box out completely, made sure the plug was back in place, I then test ran this unit set at 33⁰ for 24 hrs so far lucky not to need a new main board
reeferwrencher Thanks this. -
Hi, I have a 2012 Thermo king SB 330 when I try to start it, it goes through the cycle but then before it starts, it shows no communication on the screen. I’d greatly appreciate it if You could give me some advice for things to try to resolve this issue thanks in advance
