ThermoKing Reefer Code 23
Discussion in 'Refrigerated Trucking Forum' started by sonnyca, Mar 14, 2024.
  1. sonnyca
    sonnyca Light Load Member
    56
    14
    Oct 19, 2023
    Hello - The Reefer Unit showed a CODE 23 and the driver cleared the code, After clearing the code reefer unit started again. I checked online it Code 23 is RED and it says "Cooling Cycle Fault"
    My main concern is that we were hauling a load of -10F. When the driver cleared the code and restarted the reefer unit, it showed the temp of 6F but it's coming down slowly as I type this message it is now at -7F
    Do you think the load is messed up?
  3. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    From my experience receivers aren't super strict on frozen loads. I've heard they can be with ice cream (-20°) because frost starts to develop. But that is moot. I've often set start-stop range for 8-10°, depending upon the product and customer, and never had a problem. I wouldn't put off trying to figure out why it coded and shut down.
    lual Thanks this.
  4. scarecrowman01
    scarecrowman01 Bobtail Member
    7
    Mar 16, 2024
    Heartland
    Cooling Cycle Fault (Zone)(23) - Clear it first, if it stays away you should be good. If it codes out again, you'll want to call Dispatch to get routed to a ThermoKing for refrigeration issues.
