Thermoking evolution ran out of oil.
Discussion in 'Questions From New Drivers' started by mitten, Jan 25, 2019.
  1. mitten
    mitten Bobtail Member
    33
    4
    Jun 10, 2009
    starr,sc
    My apu wouldn't start and had red triangle and said eng...I checked it and was completely out of oil. I put oil in top fill. Still won't start. Any advice would be appreciated. Also was wondering if it has safety feature to turn off so it doesn't burn engine up if it runs out. Thanks
  3. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    I’m assuming you reset the apu? If you haven’t, I would try that first.
    Tombstone69 Thanks this.
  4. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    Most of the time if an APU happens to stop the whole unit is out. Find the reset and press it. Most trucks I had that reset was under the bunk.
    mitten Thanks this.
  5. mitten
    33
    4
    Jun 10, 2009
    starr,sc
    Going try..not sure where reset is in side box. Thanks!
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Unless you simply haven’t checked the oil in months and it slowly burned through it all, and assuming we’re talking about a newer unit, you better also check for oil leaks if you ever get it started.
    If it leaked, I’d suspect you’d be able to see evidence of it still. If it burned through a quart in a relatively short time, something is wrong in that scenario, too. Do you run it continuously or in some sort of auto mode?
    I’ve heard of them being improperly set up and they’ll run 24/7 practically no matter if the truck is parked or running down the road. That would lead to seriously shortening it’s useful life.
    Grubby and mitten Thank this.
  7. mitten
    33
    4
    Jun 10, 2009
    starr,sc
    I only run it at night..so no it doesn't run 24/7 ..they worked on it couple months ago ..it wouldn't start. When it got going it smoked a lot but they said its fine. I didn't check oil since they just worked on it not long ago...I should have and have no excuse except I just forgot till I had issue. I'm a dumb ### . hope it didn't burn engine up.. Thanks
  8. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    My low hour carrier APU will require about a half quart to bring back to full after about 2 months of running during most breaks on various start/stop modes (heat, cool, and battery maintenance)
    They’re easy to overfill. Not sure how detrimental that might be.
    mitten Thanks this.
  9. mitten
    33
    4
    Jun 10, 2009
    starr,sc
    Not even showing on stick after I put oil in.
  10. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Do you know the oil capacity on the apu.
    mitten Thanks this.
  11. mitten
    33
    4
    Jun 10, 2009
    starr,sc
    No..I just put in half quart to see. Can't get shop to answer me back about any of this. I can't find reset switch anywhere...we have bunk heater separate so who knows.
