THERMO KING Tri-Pak APU
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TLGken, Feb 15, 2009.
  1. TLGken
    TLGken Light Load Member
    75
    8
    May 18, 2008
    Dallas, TX
    Just got a new peterbilt in january, has the tri-pak on it. Has anyone had any (major) problems with the thermo king units? Mine quit working about 2 weeks ago, due to a broken connection at the altanator on the apu. Fixed now, thanks to warranty work at a thermo king dealer.
  3. U2Exit
    U2Exit Road Train Member
    2,353
    1,051
    Feb 22, 2008
    WA and VA
    but I have had the alternator connection problem 3 times now.
    Im company driver and dont have to worry about repair bills... but it is annoying having the down time to get it taken care of.
  4. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    had mine 2.5 yrs. lost freon 4 times. they cant find leak. works for about 4 months then quits. had alt wire problem once.
  5. U2Exit
    2,353
    1,051
    Feb 22, 2008
    WA and VA
    I had the leak too... they couldnt find it either, until I had some Ice and snow build up on it. Looked like a cherry snow cone was building up near the leak.
  6. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    where was the leak ? im thinking mine is compressor seals
  7. Dark Wolf
    Dark Wolf Light Load Member
    65
    13
    Jul 28, 2008
    Belding, Mi
    The first truck I had with the Tri Pack would not cool enough.....I was sitting donw in El Paso, TX...90 degrees outside APU would only get the truck down to 75...So I ran it called the shope took it in they fixed it after that I had it down to 56 in the truck when it was 85 outside......
  8. papa102498
    papa102498 Bobtail Member
    Greenwood, IN
    Wanting to do an oil change on my tri-pak and this is the first one i've ever had/used. There is almost 9000 hrs on the clock and I have no idea the last time it was done by the previous owner. Does any one know what brand and weight of oil Thermo King / Yanmar recommends in their engines and how much is need for an oil change?
  9. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    Just like Webastos they will last longer when you use them once or week even if you don't need them. If you don't use an A/C unit the seals gradually dry out and leak and you'll never get rid of all the leaks later.
  10. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    I have nearly 12,000 hours on my APU. Lessee... a couple of fuel leaks, coolant leak up in the corner where the hose comes into the unit from the engine compartment - I fixed that with a new hose clamp, and the alternator failed this winter. Oh, yeah... missing screws.
    Actually I love the thing, except when it isn't working. Considering the abuse it takes, it's probably a wonder that I haven't had more problems with it.
  11. fairlanegt390
    fairlanegt390 Bobtail Member
    there is a recall refit for the tripac because the wiring was routed wrong and it likes to burn through the battery cable. they tyed it to the exaust for some reson.
