THERMO KING TRI PACK APU heater wont work
Discussion in 'Trucks [ Eighteen Wheelers ]' started by doublew, Sep 28, 2012.
  1. doublew
    doublew Light Load Member
    68
    7
    Oct 17, 2010
    Kansas
    i have a tri pack and i switch it to heat and it just blows cold air the heater hose valves are turned on and i can feel the lines going to the APU and they are hot but no warm air no fault codes any ideas
    thanks
  3. Ukumfe
    Ukumfe Medium Load Member
    301
    515
    Oct 23, 2008
    The heaters on Tri-Paks are notorious for the screens plugging and the burn tubes failing due to the crappy fuel. Odds are one of those items is your problem. Talk to a dealer about proper upkeep to get the most out of the heater or talk with them about going to kerosene for the heater. Kerosene burns cleaner and the heaters have less issues.
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    If you are talking the bunk heater, the service kit for that thing is $210 from Thermo-King. It comes with the new screen and a glowplug for the bunk heater.
    It also has a new filter for the fuel pick-up that is on the frame rail by the fuel tank.
    You do service this thing on a regular basis correct?
  5. doublew
    68
    7
    Oct 17, 2010
    Kansas
    i just got the truck and i have never had a APU before i did change the oil and filters on it when i got it...so if i am understanding this right the APU does NOT work like the heater on the truck ( hot coolant + air bolwing across a coil = warm air out the vent...
  6. MNdriver
    7,985
    4,371
    Feb 24, 2012
    the bunk heater is not like you are used to.
    On the frame rail, you should have a filter/pump for the heater.
    You will hear the bunk heater kick in and start to blow and as it warms up, it may speed the fan up and then slow it down once the cabin is up to temp.
    This has a glowplug that goes into a combustion chamber and it fires the fuel and that warms the air. Uses very little fuel to do it too.
    I have not put my service kit into my heater. Not sure if I am going to this fall. It's working like a dream. But it's also 80 out this weekend and not sub-zero when it's likely to give me fits.
    On the APU, look at the wire going to your starter and also on your Eng On switch AT the APU.. Mine just started acting up on me and would stop running once it started, it would die.
    Both my starter wire and my Eng On Switch were corroded to the point they failed.
    I have the service kit for them and there are two fuel filters AND an air filter. You may also have to put in a new idler pulley for the alt/AC comp belt. This is a known problem I found out on the older units unless you put the new idler on it.
    I have put on a new compressor belt and still need to put my waterpump belt on. I was hoping to have done it when I put in new motor mounts, but ran out of time and it got scratched for now.
    I am hoping to open up the APU again this weekend and do all of that work now.
  7. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    It's a fuel fired heater, and it has a flame sensor that gets screwed up, I would go through a heater start thing as many as 4 times to get mine going and try to shut it down with the controls instead of letting it shut down when I started the truck, it worked a little better. The actual heater is under the bunk centered in most trucks, and has inlet and outlet tubes, these mustn't be obstructed, and it gets hot enough to explode water bottles if they are left where the heat hits them directly, so don't keep anything flammable or meltable close to the bunk
    Sometimes, it would light the first time but the APU left on the truck, and the new truck doesn't have one and isn't going to have one, either.
  8. MNdriver
    7,985
    4,371
    Feb 24, 2012
    why won't you put an APU in the new truck? just curious is all.
  9. garstein
    garstein Light Load Member
    298
    53
    Apr 18, 2013
    Lakeland, FL
    My heater works without running the APU......seems like it just runs off of the electric......
  10. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    If the heater is working right, and it doesn't matter if it's a Webasto or Espar heater, it draws electrical power from the batteries to work. In the case of the Thermo-king Tri-pac, the APU has 3 purposes, to charge the batteries to keep the voltage up, run the air conditioning, and if so equipped, to heat a portion of the main engine's coolant by using that in place of a radiator on the Tri-pac unit itself.
    AC electric is supplied by a Xantrex 1800 watt continuous inverter which carries the TK brand. I never was able to run a heavy load with the main engine shut down while using this inverter.
    Also, as the components age,i.e. the ones replaced with a rebuild of the heater, having the higher voltage available when the APU engine is running can sometimes make the difference between working or failing to light.
    Straight Stacks Thanks this.
  11. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    The newer TriPacs now have 120amp alternators, the originals were only 65amps, so running a microwave would kill your batteries over time. I have a new Evolution model, and have found out that the alternator is way too smart. It will only put out limited amperage when the AC is on, because if it was at full output, while the compressor was on for the AC, it would be too much load on the engine, and plug up the unit's DPF too quickly.
    But to the OP's heater issues. The heaters do not like biodiesel or additives. Mine also does not like altitudes over 5000 feet. ThermoKing does sell a special high altitude fuel pump for the bunk heaters, but I did not get a price. They have also recommended running it on kersene for an hour or so when you change the filters and screens.
