Thermo King SB3 + CODE 20 Vapor Motor CR
Discussion in 'Refrigerated Trucking Forum' started by Jezwa, Aug 14, 2019.
  1. Jezwa
    Jezwa Bobtail Member
    19
    Jul 26, 2019
    Thermo King SB3 + Started throwing A Code 20 and will not start in auto start. I replaced the fuel Filter but it did not fix the problem, After I clear the Code I can start it in Manuel Mode. Any help?
  3. 062
    062 Road Train Member
    6,143
    33,156
    Oct 20, 2013
    Several things can cause that code. When it starts does it sputter? What is the battery voltage?
    On the one I have it was a bad ground. You’ll have a main ground for the battery, then another with 3-4 wires. My problem was with the 3-4 wire ground.
  4. Jezwa
    19
    Jul 26, 2019
    I will look and see. I thought maybe it was vapor locking . Once I clear the code and flip at the manual it starts just fine .
  5. Jezwa
    19
    Jul 26, 2019
    Voltage is 13.6 oil is 63 psi coil 32.6 the Amb air don’t work. Rpm 1600 DDUR 43
    Hours 35218 water Temp 184.3F
    Amps 0.8
  6. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Fuel solenoid isn't energizing in auto. Do you know if the engine is yanmar or isuzu ?
  7. Jezwa
    19
    Jul 26, 2019
    It’s a Isuzu
  8. Jezwa
    19
    Jul 26, 2019
    It will start and run maybe 6 times then on the 7th it won’t I did notice the starter Grinds when it does it
  9. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Is it starting on auto now
  10. Jezwa
    19
    Jul 26, 2019
    It does. However stops on the 6th or 7 runs then flashes the 20 Code
  11. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Run it on continuous until you can get it to a shop to have it fixed... Or until you can figure out how to fix it yourself.
