Thermo King error code 25 troubleshooting help
Discussion in 'Refrigerated Trucking Forum' started by lastgoodusername, Jun 28, 2015.
  1. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    Reefer will run for 30/45 then cut off. clear code 25 , starts up, repeats . voltage on alt is 14.6 when running. replaced start stop switch, still having same problem. Any info will be greatly appreciated. Thanks, Johnny
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,948
    Jan 18, 2011
    It is an alternator code--so start w/small stuff--belt tigthness--connections etc....and have you cleared code and run in cont mode to see what happens? could also be bad sensor--but troubleshoot small obvious stuff 1st
    lastgoodusername Thanks this.
  4. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    belt is pretty worn, adjustment to the end but it is tight, running in cont mode. seems weird cause she will run like i said for 30 to 45 minutes , then shut off
  5. Flyer
    Flyer Light Load Member
    183
    88
    Jan 20, 2008
    How many amps is it pulling ?
  6. Flyer
    183
    88
    Jan 20, 2008
    Replace belt, have alternator checked, check amps it's pulling, check battery and connections.
  7. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    not sure , i will check it.
  8. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    Have yo ever cut the diode out of the alt harness, and ran it that way?
  9. Hilo_girl76
    Hilo_girl76 Bobtail Member
    I'm having the same issue with code 25, brand new alternator, brand new belt, brand new battery. My reefer still runs and temps drop normal, no issue with the reefer cutting off, just the code 25 popping up every 30-45 minutes
  10. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Reason for edit: Wrong post
  11. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Sorry replied to the op did you fix it?
