Thermo king codes 3 and 11 Help!
Discussion in 'Refrigerated Trucking Forum' started by Jennyspete, Jan 5, 2019.
  1. Jennyspete
    Jennyspete Light Load Member
    66
    45
    Apr 3, 2010
    ma
    Hi
    I have a ThermoKing SBIII. Its giving me codes 3 and 11. Unit is set for 0 but display shows its 13 in the box and unit doesn't turn back on.
    I've read what the codes mean. Seems like there is a problem with the return air sensor.
    Wondering if there is something I can check.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Put it through a defrost cycle to make sure that's working,otherwise it's likely a bad return sensor or the two pins that connect it to the micro.It's a good idea to change the sensor and pins and the sensor grade has to be calibrated to the correct number in the micro.So you might want to take it to TK when it's empty.
  4. Krhaulin
    Krhaulin Bobtail Member
    30
    5
    Dec 4, 2016
    Hello. Did they solve this? today, my unit is showing the same. code 3 and 11, have it set at 34, but display showing 44.
    thanks
  5. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Is the defrost cycle working?
