The 'tractor protection valve'
Discussion in 'Questions From New Drivers' started by KF7WTV, Sep 1, 2012.
  1. KF7WTV
    KF7WTV Medium Load Member
    410
    234
    Aug 8, 2012
    RENO, NV
    So I'm gonna be taking my pre-trip inspection test in a few hours, and I got to wondering. I know that the red trailer air supply valve is also called the tractor protection valve. Does that make the yellow tractor air supply valve the 'trailer protection valve', or is there no such thing? :biggrin_25511:
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    The red knob is not the tractor protection valve. The tractor protection valve is at the rear of the tractor where the hoses connect to the tractor. The red knob is the trailer charge valve. It's also called a push/pull or PP valve. The yellow knob is tractor parking brake valve which is also called push/pull or PP valve. The red and yellow knobs share one valve that perform both functions.
    The red PP valve being called the tractor protection valve is very outdated but was common at one time.
  4. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    no such thing
    the red value is call the tractor protection valve because when pulled it protects the tractor air supply.. when pulled no air will leak out if the red/blue lines (bobtailing)
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Wait until they ask what the blue valve does!
    CAXPT Thanks this.
  6. nicholas_jordan
    nicholas_jordan Medium Load Member
    608
    101
    Mar 31, 2012
    temple texas
    flood: --> so will it stay in the charged position if it is pushed into the charge position with the yellow tractor "parking brake" in "parking" position [extended] ?....
    bender: --> so where would we find mechanic level manuals for the valve and what is it called?.....the people who write the study materials we have to answer to insist on hiding that behind dash-board and getting a lap-monkey response for what it is called, most of them have never grabbed an air-line whipping at 60 psi and go blazitzo if you try to tell them the most air systems are not plastic knobs
    Cyanotic Sunrise ...... from trying to read "study materials" written by Office Orifice
  7. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    JTHub Thanks this.
  8. nicholas_jordan
    608
    101
    Mar 31, 2012
    temple texas
    TP-3DC has to balance or not based on design parameters at the original concepting,....RED blocks at TP-3DC ... there is a complete "secondary" system with brake-chanbers showing on the .pdf so since we only see one brake chamber on most axles that I have seen a rupture of membrane in any place brings the whole system to "emergency" or "parking" as there cannot be a secondary & primary membrane in one air-chamber without overly complex force-moments
    further reading on MV-3 module may reveal industry standard and ASME information on what exactly the dual-knob dashboard control actually does
    I have the .pdf saved to thumb-drive .... thx
  9. flood
    4,157
    4,020
    Dec 25, 2010
    yes it will.... i do it all the time to check the trailer for air leakes
    when i hook to a trailer i pull the yellow hook up the air lines then push the red to check for air leaks when i pre trip the trailer
    pulling the red knob stops all air from going to the trailer (brakes and supply) pushing in the red supplies air to release the sping brakes, supply air to the air ride (red line) and to allow the brake pedal to send air to the trailer brakes (blue line) and yes if you have the red pushed and the yellow pulled the brake pedal will work the trailer brakes..
    pulling the yellow cuts air to the tractor brakes only setting the tractor spring brakes (parking brakes) it also pops the red at the same time doing the same for the trailer, but you can push the yellow to move the tractor (bobtailing) and the red (still out) protects the tractor from losing air (red/blue trailer air lines)
  10. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    i press the trailer air supply in when im parked bobtail sometimes. you would be surprised at the amount of water that will blow out of the lines. and yes, it can still blow water out of the lines even if you make it a habit of draining your tanks. not a bad thing to do now and then. just make sure you have the lines under control or they could fly around lol
  11. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    When they call the red (trailer) knob the tractor protection valve in testing etc you have no choice but to go with it and know what they are referring to (the red knob on the MV3 push/pull module valve) but the truth is that the tractor protection valve (marked TP on schematic) is an automatic shuttle valve that is designed to stop high volume air loss in the event of a severed or disconnected trailer air line or other trailer leak source. The red push/pull knob sends air to the tractor protection valve which in turn feeds the trailer.
