Whether you are an O/O or a company driver, you should always be looking for the "sweet spot"... the combination of mph and gear ratio that will yield the best MPG. What is your current set up and "sweet spot"?
My brother and I are driving a 2003 Kenworth with 13 speed transmission, and our sweet spot is about 69-71 mph in high gear. I've often read about other truckers having the sweet spot near 61-62 mph, and we've tried many different combinations of gears versus mph, but can't find a better spot than about 70 mph in highest gear...
The "Sweet Spot" (best MPG)
Discussion in 'Experienced Truckers' Advice' started by Lepton1, Apr 7, 2013.
Page 1 of 9
So u found ur sweet spot above 70 miles an hour 71 lol
I'm driving a Volvo with a 10spd and it seems to get the best fuel economy at 57-59mph in 10th gear at around 1250rpm. I've also noticed that I get better mileage when I pay close attention to my shifting points. I still have a lot to learn about this whole business.
I have a 2013 T700 with a 455 MX and a 13 speed. Rear end gears are 3.34. I keep my boost below 20lbs and my rpm's between 1250 and 1450. Hard to say what speed I cruise at since I'm rarely on the flat and get better MPG by not running cruise control. I average around 70,000 - 80,000 lbs gross running between Denver, Seattle, and LA. I'm usually getting mid to high 6's between Denver and Seattle and mid to low 7's running between Seattle and LA. I don't run overdrive in the 55 mph states and only use the overdrive once I get above 60 or so. I'm paid according to my MPG so I keep a pretty close eye on it.
I've got a DD515, for me its 59 mph, but it varies wildly due to wt, hills, wind, you name it, its almost impossible to be consistent it seems. I am almost wondering if fuel consumption is also based on attitude. I do a lot of the west in high elevations, and I am convinced it has an effect on my fuel = thinner air = richer fuel being burned. I just don't know.
Must be a real bummer when you cannot run that speed
flightwatch Thanks this. -
My company pretty much preaches low rpms. I ran at 53 the past couple weeks, 1150 rpm, mpg last week was 8.6 and the week before that was 8.1. This week I had to run 65 @1450 rpm to make an appt. and burned over 100 gal. of fuel in a day and I'm at 6.8 mpg.
Speed limit in Texas is 75.
Today's word of the day is...
limit
Page 1 of 9
