I now have a truck with a Rockwell 10 speed. I have driven the Super10, Eaton 10, Super 18, 9 speed, 5, 5 + 2, 6, and 7 speed. I can Shift without grinding or luggin. With this transmission its difficult to downshift and idk why. This is the transmission that makes me look like i just graduated 4 wheeler school. UGH. My question is have anybody else had shifting issues with their Rockwell 10 speeds? ( just on the downshift)
The Rockwell 10 speed Downshift
Discussion in 'Ask An Owner Operator' started by truckman29801, Nov 10, 2013.
are you flipn down before moveing gear stick?
It has finer teeth on the gears, so the synchronization between road speed and engine rpm must be closer before it will shift properly. Also, you don't mention which particular shift you are having trouble with, but if it requires the stick to make a lateral move, you can't "cut the corner" with a Rockwell and make a kind of diagonal move with the stick like you can an Eaton. You have to "square" the motion when going into and out of neutral or you'll never make it shift right. Once you get used to it, I think you'll like it though. It's just got a lot closer tolerances than the Eaton does.
Yeah i have noticed, the rpms have to be exact.Or it wont let me ingear
I liked them, the last one had an electric over air on the range shifter, and it was fast. This is the first Eaton 10 that I have liked, and it was almost new and not a reman.
I hear they are pretty tough? Not much play in the unit itself. Im learning to like it.
They're very tough. I had several and after a few teething problems with the earliest production models, they were great. I should have asked you, what is the year of your truck? We had some shifting problems with the early ones when they got warm. The expansion from the normal operating temps. was enough to cause a bind in the shift fork. The solution was to double gasket the top cover of the transmission. That provided enough clearance that there was no more binding and the things shifted beautifully.
Its a 99 transmission.
That's late enough that the shift fork issue should have been addressed. I doubt that is the problem....
The owner's 92 had one she took drivers on road tests with to make sure they knew how to shift. I was possibly conceived in a truck as my parents both drove until I came along. So, while I can see how it would take some getting used to coming from an Eaton, and most people hated them, I never had a problem.
