The Relationship Between Squelch and RF Gain
Discussion in 'CB Radio Forum' started by madmoneymike5, Oct 2, 2019.
  1. madmoneymike5
    madmoneymike5 Medium Load Member
    633
    283
    Jan 30, 2010
    Arlington, TX
    How would you describe the difference between RF Gain and Squelch? I mean, I know what they are, but under what circumstances would you decide to adjust one rather than the other? In laymen's terms, please!
    Thanks!
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    RF Gain fades the signal out when turned down...Squelch cut's out the static sound when turned up...With squelch turned up you can adjust the radio so you only hear strong stations break threw the squelch...With RF Gain turned down you still have a static sound (not as loud tho) and only strong stations can be heard...
    Me personally, I leave the RF Gain wide open all the time so I can hear those guys that maybe 10 miles down the road...If I'm traveling with someone close by, then I turn the squelch up to where only that driver will break threw....
  4. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    That's the way I always do it as well.
    madmoneymike5 and Diesel Dave Thank this.
  5. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    That's what I've been doing. But just didn't know if there was a scenario where it would be better to turn RF Gain down and how much.
  6. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Squelch puts up a wall so weak signals won't make the trip.
    rf gain is like pulling down a window shade and it cuts the noise, but still allows weak signals to come through only if squelch is wide open.
  7. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    So when would you want to adjust the window shades rather than the wall, and vice-versa?
  8. Ridgeline
    22,103
    113,210
    Ok the rf gain turns down the rf coming into the radio, you can see when you have a strong signal coming in and you can see by turning the rf gain down and the signal will go down.
    Think of it as a rf "volume" control.
    Weak signals are eliminated when the rf gain is turned down.
    Squelch is to eliminate the noise and signals from the audio, like a variable audio switch.
    With it turned down, it let's all noise and signals to be heard, with it turned up to a level where it is set at a level where the signal is not heard, it is quiet.
    You can turn down the rf gain and adjust the squelch to stop the noise and you won't hear a thing.
  9. Night Stalker10
    Night Stalker10 Road Train Member
    1,667
    1,242
    Jun 26, 2017
    In layman‘s terms, you use the RF gain when you’re sitting close by another truck (like in a truck stop), so that persons radio won’t overdrive the receiver in your radio
    madmoneymike5 Thanks this.
  10. booley
    booley Road Train Member
    1,408
    9,352
    Feb 16, 2008
    and preferably, the carpet should match the drapes...
    Oxbow Thanks this.
  11. Timin770
    Timin770 Road Train Member
    1,657
    1,757
    May 27, 2011
    Canton, GA
    Brokeback Mt
    Art Vandelay Thanks this.
  12. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Which one would be Dunning? Which would be Kruger?
