The ideal truck speed set up?
Discussion in 'Ask An Owner Operator' started by ihaveaquestion, Jan 10, 2024.
  1. ihaveaquestion
    ihaveaquestion Medium Load Member
    306
    174
    Jan 3, 2024
    The question is for everyone, company drivers, contractors, owner ops, what is the most ideal truck speed 70? 75?
    Obviously when we’re loaded, we all hit the hill we all slow down; with all the variables in mind, different speed limits in different states, this company does 65 because of insurance then there’s an owner/op doing 90 in the left lane lol.. also with the thought in mind that all brokers set shipping schedule at about 50 mph.. with all the variations factored what’s the ideal effective & efficient mph?
    Kyle G. Thanks this.
  3. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Between 65-68 is what you want to do on the majority of the drive for a good balance of time to get there and ok fuel mileage. If you want great fuel mileage you want to stick around 55-60. But personally I think governor should be set to 75mph to initiate quicker passes. Problem is majority of company drivers tend to want to drive as fast as the truck can go. So accounting for modern day bonehead drivers now a days I would have the governor probably set to 68 and maybe see if I could out some kind of passing mode that would set it to 72 for 60-90 seconds at a time that would limit to 3 uses every hour.
    WWWx3, 86scotty and Kyle G. Thank this.
  4. Iamoverit
    Iamoverit Road Train Member
    1,549
    3,363
    Oct 31, 2023
    No such thing. There is no one size fits all here.
    BoostedTeg, 86scotty, Numb and 3 others Thank this.
  5. Concorde
    Concorde Road Train Member
    4,345
    15,433
    Jun 29, 2016
    West Melbourne Florida
    85 South Dakota is ideal for me :)
    Numb and Kyle G. Thank this.
  6. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    3 digits, baby:eek:,,hey, I knew guys 20 years ago that spec'd their trucks to do 100. Whatever you do, DON'T do the 65-68 mph thing. You'll plod along with all the other 65-68 crowd, and the 4 wheelers behind you getting madder and madder. For today, I'd say a truck should do at least 75. Years ago, tires were a big factor in going those speeds, not to mention, the trucks couldn't go that fast anyway, but today, I think modern tires can handle a load at 75 no problem. Fuel mileage doesn't seem to differ, at 55 or 75 much. And if you had a CAT motor, you wouldn't slow down on the hills,, :thumbup:
    Kyle G. and Concorde Thank this.
  7. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    Spec the gears to allow you to do 85 on the governor so you have some top end passing speed over the megas and zombies, and freedom to run if need be. Normally settle in and Run in the “sweet spot” of the truck were the engine can just “breathe” on its own without being forced to run. In my experience its usually around 65 mph range. Your truck will tell you were it likes to be.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Back when the national 55 limit was the rule I thought that to be a bit slow.
    Later at 75 I found that to be too fast as things that happened on the road, the required reaction time and speed really limited your options to maintain a safe stopping distance.
    I eventually personally settled in at 65 as a reasonable compromise.
    There is no ideal truck speed without adding under what circumstances.
    Fuel economy, several years ago a European study found 45 mph to be the idea speed. Trucks averaged 13 mpg.
    Time, obviously the faster the better.
    Safety, something close to maintaining the over all traffic flow.
    Profitability, depends what the freight pays vs how low you can keep your expenses.
  9. OLDSKOOLERnWV
    17,814
    268,544
    With 3:70 cogs on 24.5 tall i top out about 85 mph. But find cruising at 65-68 mph empty or loaded gives me my best economy and performance with my dinosaur…..
    01HFT, Oxbow, 201 and 2 others Thank this.
  10. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Every company is different, every route is different. I just bid a year long contract that is 520 miles a day, loading/unloading each morning. There’s no incentive, HOS or more freight hauled, to go fast, in fact, great fuel mileage is factored into the bid. Another run I do, I try to maximize speed average/HOS to enable a second run the next day if available. Current trucks are set at 80mph, but has a tattle tale for more than 73 for over a minute. That’s enough to pass and get out of the way, but not getting to play Billie Bigrigger with my fuel and truck.
  11. Kyle G.
    Kyle G. Road Train Member
    3,759
    19,630
    Jan 23, 2016
    Eastern Iowa
    Our trucks are all different. Some are as low as 68, some 70, some 75. Mine was 75, but since I switched to tall tires I can actually get it up to 78 now (don’t tell anyone).
    Problem is, some of our idiots think they should just put their foot to the floor and do 75 all day no matter what the speed limit is, and I don’t agree with that. I rarely go above 72 unless I am passing someone. It makes for a much easier and less stressful drive when you do 2 or 3 mph below your governed speed.
    201 Thanks this.
