Testing unloader - purging too frequently
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by moocowman, Oct 11, 2017.
  1. moocowman
    moocowman Bobtail Member
    9
    2012 International 4300. Air brakes purging about every 45 seconds. Checked for air leaks, found none. Replaced governor. Still doing it. I've heard about using shop air to test the unloader, but don't know how exactly. Where to I inject air, to the air tank? I'm supposed to listen for air leaking out the compressor intake, correct?
  3. iRookie
    iRookie Light Load Member
    140
    174
    Aug 16, 2015
    Spray soapy water around compressor, unloader valve, fittings, airbags.
    We had similar issue and we were able to resolve it by replacing the unloader valve fitting and air compressor discharge hose/line.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    If your compressor has another mounting location for a governor, you can remove the port plug and apply shop air there and listen for air leaking out of the intake. If not, you have to unbolt the governor and try. You can also pressurize the wet tank with shop air so the governor hits cut out pressure and listen that way too. Whatever is easier. Another give away of bad unloaders is the rattlesnake sound coming out the purge valve of the air dryer.
    QUALITYTRUCK Thanks this.
