TCS light - stays on --> Volvo 2012 - 670
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JerryD13, Dec 2, 2017.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    I took it to a mechanic to Clear the light and it worked for about 5 miles then Back ON Again ??
    Q: HOW can I turn off this TCS LIGHT ON DASH - Picture attached PIC 2.jpg
    Thanks
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    My truck is an '01, my light comes on when I start the truck so I just push the TCS button and it goes away.
  4. mitmaks
    mitmaks Road Train Member
    2,543
    2,065
    May 16, 2014
    Does it give any codes with it?
  5. JerryD13
    169
    126
    Oct 17, 2016
    no codes - light just stays on ?
  6. RoadRanger^^
    RoadRanger^^ Light Load Member
    265
    105
    Apr 17, 2018
    Columbus, OH
    I got the same issue. Volvo 2011 w cummins isx engine. TCS light came on and never went off. It shows the code:
    1. MID 136 SID 77 fmi 2
    Anyone has an idea ? Some ppl say it’s the air pressure sensor. I also noticed when i turn my key igniton on and my truck do all the check i cant hear air like it was supposed to release. Please help!
    Last time i got this light on my truck, my truck got on fire and my drive wheels fell off.
    Mjgeorge301 Thanks this.
  7. althebig
    althebig Bobtail Member
    9
    I have the same issue, TCS light on, no faulty codes, Volvo 2008.
    Did you fix the problem? If so, what was it?
    Thanks
  8. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I saw an International truck that had the same problem - TCS light on with no code - and it ultimately turned out to be a rub in one of the wires at the back of the dash. Please let us know if you get it resolved.
  9. althebig
    9
    It was the sensor in steering wheel. I replaced the steering column, and in the proces of the installation, the steering wheel was about 90 degree crooked than is supposed to be, i noticed it when i took the test drive. At the same time i got the tcs light on. After the test drive i straighten the steering wheel but the light was stil on, so i went to the shop where they reset the sensor inside the steering wheel, and voila, no more tcs light and no $100 bucks in my pocket. #$@#~%$ volvo.
  10. Azizusa1
    Azizusa1 Bobtail Member
    4
    I’ve TCS on in my Volvo 670(2014).
    Anyone fixed???
