TCS ,and ABS( on the truck) lights on
Discussion in 'Volvo Forum' started by Jultrans178, Jan 12, 2020.
  1. Jultrans178
    Jultrans178 Bobtail Member
    8
    Hello everyone!
    I'm in need of help in regards the TCS and ABS ( on the truck), please.
    The codes that I got on the computer are in the Brake ECU tab:
    MID 136 SID 89 FMI 2
    MID 136 SID 4 FMI 14
    My unit it's a 2012 Volvo vnl 670 ,Cummins isx ,13 speed.
    Vin CN 553443
    So the TCS light in the cluster it's solid ON, the switch on the dashboard it doesn't do anything if turned on/off.
    It started to be like this ,ON ,since I tried to enter the shop where the ground level was different, so I switched ON the front axle switch in order to move .Since then the TCS stayed on. While trying to switch it off from the button it doesn't do anything.
    I greatly appreciate your time and expertise into all your answers posted above. Hope you can help me.
    Thanks allot !
  3. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    Pull the plastic kick plate off on the lower left by the tilt column pedal. Check the pressure switches on the firewall. Pull the electrical connectors off one at a time and look for green corrosion on the connectors. Chances are water got in them and shorted the switches out.
    Jultrans178 Thanks this.
  4. Jultrans178
    8
    Thanks allot Mudman78!
    After reading everything that was posted here in regards the TCS ,ABS , I will definitely check on those 4 or so,sensors.
    Still trying to get information on those 2 codes.
    Thanks allot!
  5. Neilwhayes
    Neilwhayes Bobtail Member
    30
    25
    Jul 8, 2014
    miramichi nb. canada
    this code is for the steering column sensor it is linked to the abs/traction control system
    i believe usually a problem with a coroded wire, mine was a connector under the cab on inside of frame rail
    sid 4 is your front drive axle, right side wheel, abs fault
  6. Jultrans178
    8
    Thanks allot Neilwhayes! Much appreciated your time into it.
    I will finish this week loads and bring the truck to the shop to check on the Steering column sensor and the ABS sensor on the FR steer axle.
    Much appreciated again!
  7. rlupright
    rlupright Bobtail Member
  8. rlupright
    Did you ever get your TCS light to go off , if so what was the fix , having the same issue with my Volvo , pretty much the same issue , spun the drive wheels entering a drive way and TCS light came on , truck is in the show , they are saying it needs a new ECU $4500 , any help would really be helpful.
  9. Volvo_780
    Volvo_780 Bobtail Member
    26
    Feb 22, 2021
    Did you end up fixing the problem?
  10. Volvo_780
    26
    Feb 22, 2021
    It is not your ecm I got the told the same thing replaced it paid for a new ecm and did the same problem only problem with me the TCS came on just cruising down the highway Nd it came on losing throttle and power it’s been at 6 shops and no one can figure out the problem
  11. teemobile707
    teemobile707 Bobtail Member
    47
    30
    May 1, 2020
    Hello gentlemen,
    In reading your post on the TCS light I have a question / comment.
    I just replaced my kingpin bushing and bearings as well as the tie rods and center link assembly. The TCS light never came on unless turned on by button on dash. AFTER the kp and tie rod work the TCS light is now on and I cannot turn it off. Could this some how be tied to a bad ABS sensor? Just thinking outside the box here, seeing how this problem did not show up until after the work. I also changed the inner and outer wheel bearings while in there. Figured to ask y'all. Hope that helps and any input is appreciated too.
    Thanks,
    Tee
