Tc warning sign
Discussion in 'Ask An Owner Operator' started by Ikamob01, Apr 23, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Will dot shut you down for a Tractor control (tc) Light on.
  3. JonJon78
    JonJon78 Road Train Member
    7,041
    37,560
    Jul 1, 2018
    It's a violation not OOS though
    Siinman Thanks this.
  4. Ikamob01
    314
    195
    Dec 4, 2021
    Like how much?
  5. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Could be just warning
    Siinman and Ikamob01 Thank this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Check switch if you accidentally turned tc off it lights up dash. If traction control had a issue it would likely be a abs sensor which would show a fault as well..tc light alone wouldn’t be a dot issue IMO
    Siinman, JonJon78 and Ikamob01 Thank this.
  7. JonJon78
    7,041
    37,560
    Jul 1, 2018
    I was thinking ABS was on as well with the TC light, so I believe you are right if just the TC light is on, it's not a violation.
  8. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    I don’t think abs light is a violation either. Last time I read the regulations it just said the light had to work and come on for a few seconds when you turn on the key.
  9. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    I had this problem and it was a speed sensor that was a snap to replace.
