Tarping the front of a load of pipe?
Discussion in 'Questions From New Drivers' started by eddy6053, Apr 11, 2010.
  1. eddy6053
    eddy6053 Bobtail Member
    Rochester, Mn
    Am wondering how much difference it makes to put a tarp up in front of a load of... say pipes or culverts.. to try to cut down on the amount of drag... I see it once and a while...am wondering if it improves mileage much?
  3. BIG RIGGER
    BIG RIGGER Road Train Member
    1,071
    414
    Feb 25, 2010
    Fargo,ND.
    The shipper requires it to eliminate smoke damage to the pipe from the truck's stacks.If you have grass burner stacks it's not required.
  4. jakebrake12
    jakebrake12 Road Train Member
    1,576
    1,047
    Feb 15, 2008
    I95
    Hence the term.. Smoke tarp.. You'll notice this is required on a lot of different loads that really don't need to be tarped.
    Big Don Thanks this.
  5. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    It would probably have a negative effect on fuel milage if it had any effect at all because the wind will travel through the pipe and the tarp just blocks it creating a little more wind drag...
    But that's not why we use them, They're called smoke tarps and they're there to keep exhaust from contaminating the pipe.
  6. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
    Now let's see....
    I have a CARB approved engine in my new rig....supposedly the "air" leaving the stacks is cleaner (in some cases) than the "air" going through the intake.......
    Now that being the case....why do should we be required to use a "smoke tarp"?
  7. blackw900
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    I've asked myself that question before too....
  8. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Because of the smog in Los Angeles basin area and don't forget the smog layer in SLC....the exhaust is govern-mentally proven to be clean...like AlGore's utility bill!
  9. Working Class Patriot
    12,683
    23,164
    Jan 17, 2008
    If that's the case....I would suggest the shippers shrink-wrap all loads...period...:biggrin_25523:
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    Can't do that...wouldn't be environ-mentally sound...plastic takes centuries to break down!
    BRING BACK THE GLASS BOTTLES! SAVE A LAND FILL!
  11. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    I work directly for a pvc pipe manufacturing company. We shrink wrap all of our B stock to avoid sun damage while it sets in the yard .... and company policy still requires a smoke tarp to be placed on the load. Why? Because of receivers (rejecting pipe due to possible contamination). We have to fully tarp any of our weldable pipe ... why? because of receivers (they'll reject it if its dirty). I know tarping sewer pipe is retarded .... I get to do it every day. And no ... having cal clean air cert exhaust does not exempt you from having to tarp. Tarp pay is built into the load price. It takes 15 min. Purchase 2 10x12 walmart tarps and you'll be able to cover the front of the bundles on the ground.
