Tarp repair
Discussion in 'Flatbed Trucking Forum' started by OlegMel, Sep 25, 2023.
  1. OlegMel
    OlegMel Medium Load Member
    370
    633
    Apr 8, 2023
    What does everyone use for tarp repair? I use repair kit with tarp material and vinyl cement. Tried gorilla tape but it does hold on for long.
    Anybody tried Zip Tape?
  3. OlegMel
    370
    633
    Apr 8, 2023
  4. Professor No-Name
    Professor No-Name Road Train Member
    3,907
    7,492
    Nov 26, 2016
    I've used flex seal tape. It works really well. Used to pull end dumps an would use starting fluid to clean the area around a tear. Cover area with a light coat of rubber cement. Cover that with tarp material an rub it out, then rubber cement the edges. Always carried a roll of spare tarp. Always did a fine job.
    TX2Day and OlegMel Thank this.
  5. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Tarp material and rubber cement,clean the area around the tear,light sanding to create a rough surface and make sure you round up the corners of the patch to avoid seperation later.
    Long FLD and OlegMel Thank this.
  6. Long FLD
    Long FLD Road Train Member
    11,366
    45,786
    Mar 4, 2015
    I’ve done the same as everyone else, taro material and rubber cement. I have used gorilla tape as a temporary fix until I could clean it up and patch it properly.
  7. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    My tarp repair kit consists of leaving the tarps in the shop. With time and labor involved, tarp loads consistently pay less than no-tarp.
    Tug Toy, TX2Day and Diesel Dave Thank this.
