Tarp issue
Discussion in 'Kenworth Forum' started by Movingw8inc, Mar 20, 2020.
  1. Movingw8inc
    Movingw8inc Bobtail Member
    15
    4
    Feb 26, 2020
    Franklinton nc
    Tarp was working fine then all of a sudden ya not working any advice on what to check before I go and buy a tarp motor. Thanks
    x1Heavy Thanks this.
  3. BackwoodsGA
    BackwoodsGA Road Train Member
    1,922
    9,776
    Mar 18, 2012
    Elgin Nd
    Check tarp sensor.could be bad.
    Movingw8inc Thanks this.
  4. Movingw8inc
    15
    4
    Feb 26, 2020
    Franklinton nc
    Thanks is that located on the motor it’s self
  5. BackwoodsGA
    1,922
    9,776
    Mar 18, 2012
    Elgin Nd
    On the tarps firewall actually.
  6. Chubby Fly
    Chubby Fly Medium Load Member
    569
    796
    Nov 25, 2019
    first thing you want to check is in the battery box. Those 2 heavy gauge wires from the tarp switch goes to the battery box. There should be a circuit breaker in line right near the positive wire near the battery post. Alot of guys including my self just wrap it in electrical tape instead of mounting it. I always keep a spare in my truck. sometimes they pop and need to be swapped out. so check that first by bypassing it. IF it works after bypassing, replace it. they are like 20 bucks. Next you will want to check your switch, they crap out just like the breaker. They are cheap as well.
    heres a pic of the breaker. Doesnt sound like you are, but if you know how to use a multimeter, you can easily trace your wires to see if they are hot at all the points you want to check. mainly at the motor. I have no idea what a trap sensor is and what it senses but hey maybe some triaxles have such a thing. tarper2.jpg
    pushbroom Thanks this.
  7. Movingw8inc
    15
    4
    Feb 26, 2020
    Franklinton nc
    Thanks y’all I tracked down the wire cut in half in rear under bed.
