Tanker Swerved To Avoid Disabled Vehicle With No Lights On
Discussion in 'Trucking Accidents' started by mjd4277, Dec 27, 2024.
  1. mjd4277
    mjd4277 Road Train Member
    13,880
    41,425
    Oct 4, 2015
    Fitchburg,MA
    Flat Earth Trucker, Numb and The_vett Thank this.
  3. Arctic_fox
    3,859
    19,392
    Sep 16, 2016
    Ok this one is obviously MOSTLY on the ####### 4 wheeler. Buuuuut the trucker is likely cooked too. Unless there is something not obvious from the photos he should have had time to spot and move around the vehicle. Im guessing distracted?
    Again maybe im missing something and ill be happy to admit im wrong if someone points it out, but the trucker did screw up as well. If he had to swerve hard enough to slosh over he had to be pretty #### close or going really #### fast before he reacted.
    The_vett Thanks this.
  4. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    I was told never to upset a tanker. Knock whatever is in your way into oblivion, but don't tip over a tanker. Dash cam is paramount here.
  5. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    Hopefully, I will never get in a similar situation. But I will not swerve to miss a car. You see too many tanker drivers getting killed or hurt bad when they do. If I hit someone by not swerving, I would likely stop driving, but i would be alive.
    mjd4277, Old_n_gray and 201 Thank this.
  6. mjd4277
    13,880
    41,425
    Oct 4, 2015
    Fitchburg,MA
    I had a close call like that a year and a half ago on I-10 westbound near Anahuac,Texas. Someone thought it was a good idea to leave their broke down Ford F-150 in the #4 lane (slow/granny lane) with no hazard lights or anything to warn traffic). And this was was around 10:30-11:00 pm at night, and on that particular stretch of I-10 there’s no lighting,save for the service station near where the pickup truck broke down. That area is practically swampland. If I hadn’t seen the license plate on that truck there would’ve been a wreck! That, and the fact that there was little traffic,along with being governed at 65 mph are the only things that saved me.
    The_vett and 201 Thank this.
  7. 201
    12,042
    24,575
    Apr 16, 2014
    That, and you are a good driver,,:thumbup:
    mjd4277 Thanks this.
