tanker endorsement test
Discussion in 'Questions From New Drivers' started by MarcB, Aug 20, 2014.
  1. MarcB
    MarcB Bobtail Member
    26
    Aug 9, 2014
    phx,az
    how hard is the tanker endorsement test? how many questions are on the test?
  3. C & C
    C & C Light Load Member
    71
    57
    Feb 10, 2014
    FL
  4. notsonewb
    notsonewb Light Load Member
    180
    78
    Jul 29, 2014
    Its not to bad just read the study guide until you understand it , then after you get it and actually drive a tank you will then understand what it was talking about , just take your time they ain't to bad , the modern tanks are fairly well baffled so that helps alot
  5. stevep1977
    stevep1977 Road Train Member
    3,698
    22,289
    Dec 23, 2010
    Chicago, IL
    Tanker endorsement test is the same as any other multiple choice driving test. Two completely ridiculously stupid answers to the question that obviously are wrong, one answer that is wrong, and one right answer
    example question on a driving test
    what do you do at a red light?
    A) blow right through it immediately
    B) Slow down slightly, look both ways, then blow through the intersection
    C) slam on your breaks as hard as possible immediately
    D) apply gentle pressure to the brake pedal and come to a nice easy stop
    Tanker questions won't be too much different in their level of stupidity. Two answers will be so stupid, and then you choose the best answer out of the other two.
    Then there's the "all of the above" answers. If more than one of the A B and C options are correct, it's definitely all of the above.
    etc etc
    Read through the tanker section in the CDL book a bunch of times over and over, take the sample test on here, you're home free.
    Lepton1 Thanks this.
  6. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,159
    Oct 2, 2011
    I just took mine a couple weeks ago when i renewed my DL... For Indiana it was 20 questions... I believe you can only miss 4... The pages covering it in the CDL guide manual was only 2 pages... Just ready it right before you go in the DMV and you should do fine... Just make sure you know about baffuels and surge...
  7. Tolan
    Tolan Light Load Member
    127
    52
    Sep 6, 2013
    Detroit, MI
    It is easy dont over think it. Just read and understand the cdl manual and you will be fine. The section covering tankers (at least in Louisiana) isnt very long only a fee pages I do beleive. Also they have practice test on here that help alot too.
  8. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    I've taken it in Tx and in Arkansas. I think it was @ 25 questions but I don't really know. It's on computer and as soon as I got enough correct answers to pass, the test ended without me having to see all the questions. As was recommended above, study the cdl manual and you should be ok.
  9. arewethereyet1
    arewethereyet1 Light Load Member
    205
    27
    Feb 1, 2014
    I heard it's simple. You study a few pages. Take a few practice tests to see where you're at. 20 questions I've heard, you can miss up to 4, 5+ no beuno.
  10. GWIZ2260
    GWIZ2260 Light Load Member
    90
    42
    Jul 3, 2014
    Lafayette, IN
    As others have said, very easy test. Just read the manual, make sure you understand about surge, and baffles, what to do when going through a curve, etc...took IN test and passed easily. 20 questions was correct, don't know how many you could miss.... the only one I didn't pass without reading on was the hazmat, since I was waiting they let me take all the endorsement tests... LOL, first question on hazmat, and knew I wouldn't pass... only because I didn't know some of the identifications on hazmat... only missed by one, next day after studying for about 30 minutes, went in and passed that one as well...
    The only thing I noticed on my tests (think they have several variations of each endorsement test), was sometimes the wording was different on the test from the cdl manual, and required a different answer... if you don't read the ENTIRE question, and ASSUME it was as the manual presented it, then you may be incorrect, make sure to read the entire question and understand what they are asking about.... good luck
  11. CharlesS
    CharlesS Light Load Member
    247
    104
    Aug 9, 2013
    If you can pass the General Knowledge, Combination, and Air Brakes tests the tanker should be easy. I don't remember having any issues when I took mine. Use the online study guides, but be aware each state does word questions a little differently so you may not see the exact wording or exact questions on your test. The study guides / practice tests are there to help you get the general information, its up to you to read the question, understand what it is asking, and chose the right answer. I know the online tests/guides helped me a lot. Passed all of the tests including Hazmat on the first attempt, several of the guys in my class that didn't use the online help were going back 2 & 3 times to retake the tests.
    GWIZ2260 Thanks this.
