Tanker - drivers loading / unloading responsibilities
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by MidWestLog, Apr 13, 2015.
  1. MidWestLog
    MidWestLog Bobtail Member
    6
    Aug 17, 2014
    I have a fair idea the drivers duties in fuel hauling, loading at a rack and unloading by hose at the delivery location, Could someone give me a description of the loading and unloading
    of a food grade or chemical tanker? I sure there are some differences, but I was wondering what a typical process would be like, drivers duties, time etc.
  3. kemosabi49
    10,438
    44,393
    Jan 13, 2013
    SW Arkansas
    I run chemical tank. In five years i have only actually loaded a tanker twice. Normal for the shipper to lad, though somtime I need toopen and close the dome lid. Unloading, the meaner and nastier the product is, the less likely you will be involved in the process. Usually I hand off the truck keys and go to the breakroom. On less hazardous I hook up hoses, open the valves and wait til it's empty. On occasion use extra hose and truck pump or air but then I get paid extra for that. I love doing tanker and wished I'd have went into it when I first started driving.
    meechyaboy Thanks this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Why does every tanker yanker say that...
    Cohiba and meechyaboy Thank this.
  5. kemosabi49
    10,438
    44,393
    Jan 13, 2013
    SW Arkansas
    Because we've never made so much money for doing so little work, while being home 5 nights out of every 7.
  6. Dna Mach
    Dna Mach Road Train Member
    3,252
    2,962
    Aug 8, 2008
    Texas
    We get paid for everything and our CPM's are significantly higher. No money and/or no life in trucking is a myth if you know where to look. I'll never pull anything but a tank again.
    RockinChair and Blackshack46 Thank this.
  7. 77smartin
    77smartin Road Train Member
    2,183
    3,022
    Apr 3, 2011
    I dunno.
    I do food grade (sweetners) and there is a lot of driver involvement if the customer doesn't have their own pump. All places have different rules...pretty much cut the seals, pop the lid, hook up your hydraulic hoses and the hose from your tank to theirs...then open the plunger and start your pump.
    The time depends on a lot of factors...thickness of product, if you have the tank at a good angle, your pumps performance. Can take anywhere from 30 minutes to 11/2 hours. I go to a customer that uses their pump and it takes 24 minutes...but getting the sample cleared takes 30.
    Loading is easy and done by the shipper...takes 30-45 minutes.
    All shippers and receivers are different...some don't give a crap...just do it and some have all sorts of rules which make it take longer.
    I like it...keeps me active...gotta stay on top of your equipment as well which I like doing.
  8. JoeBear
    JoeBear Light Load Member
    103
    46
    Jul 18, 2014
    Houston, Tx
    5 more months of this OTR which isn't bad at all and really do like... but I'm not home to start having kids and I spent 11yrs gone in the military came back set roots down and bam jobs dry up back on the road literally. Jus waiting to find this even if I start just pulling fuel and can get into chemical after a few yrs I'm fine with that. Cause it'll be totally worth it.
  9. ethos
    ethos Road Train Member
    4,249
    9,905
    Mar 3, 2013
    Houston
    I've loaded myself twice in my career. Both times at SafetyClean, freaking hate that place. Unloading is usually done by the customer, if I had to put a number on it I would say I do it 20% of the time. In a year here at Trimac I've done one pump off but I'm on a load now that will be number 2. Unloading varies from product to product and customer to customer.
    Generally you get there and determine if it's pump or air. Pump for all flammable unless the plant has nitrogen. Also, some products have to be pumped for a variety of reason. It's rare but some customers prefer pump for just regular products. Once you figure that out you just get the hoses and fittings you need. Hook up, air up if using that and open the valves then pull out your phone and play on the forum till the hose jumps, lol.
    There is more to it, especially when air unloading into a tank that will be close to full, bottom feeding tanks, thick products etc. If you want specifics then I could try and explain it.
  10. Grouch
    Grouch Road Train Member
    2,079
    4,243
    Feb 3, 2009
    Between here and eternity
    Hauling milk, each dairy is a little different and then it all depends on what type of tanker you are pulling. There are two types of milk tankers, transport and farm pick-up. A transport does not have any hoses or pump so basically if you do anything, it is only hooking up the hose at the dairy, but most dairies do it themselves.
    On the farm pick-up tankers, you will wash and sanitize the hoses and pump. The pump will need to be taken apart and then after you are through cleaning it, you will put it back together again(piece of cake). All this can be done within 10 to 15 minutes. Companies around here don't pay for this, they claim it is included in the trip pay.(bull)
    Mardet Thanks this.
  11. Mack185
    Mack185 Medium Load Member
    448
    262
    Feb 25, 2008
    Chemical/Foodgrade here, 98% of the product we haul is from our plants so our plant employees load it. I may load 1 in 20 but, have never loaded at the few places we pick up at. As far as unloading, we unload almost everything and I can only think of one active customer we have at the moment that unloads for us.
    All our trucks have pumps and blowers. We do a lot of solvents and such at my plant so we pump off most of the time which sucks simply because it involves more hoses and my pump is getting a little long in the tooth. We also do some food grade which is always air off and our branch across town does a lot of corrosives which is also almost always air off simply because we don't have many stainless pumps. Unloading is no sweat, you'll get used to it.
    We get two hours to unload. Sometimes it takes 3 hours, sometimes it takes 30 minutes. Time all depends on product, how your unloading it and how far it is going.
