Tandems forward or back when backing into tight spots ??
Discussion in 'Questions From New Drivers' started by Western Sky, Apr 30, 2013.
  1. Western Sky
    Western Sky Light Load Member
    67
    34
    Feb 2, 2012
    Oregon
    Is it usually easier to back into a tight spot with the tandems slid forward or all the way back?
  3. Trucail
    Trucail Medium Load Member
    611
    291
    Oct 27, 2011
    Seattle, WA
    Forward! In tight spots, and on curvy roads, always close it up. If your tandems are to the rear you will always need more room to manuever.
    jbatmick Thanks this.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I would say all the way forward otherwise you may not have enough room.Ive delivered places you have to have your tandems forward just to get to the docks.
  5. JohnBoy
    JohnBoy Road Train Member
    9,942
    26,361
    Apr 24, 2009
    Lake Worth, FL.
    Just watch your swing when you pull out of a tight spot. The overhang from the trailer might take a mirror with you.
  6. othertruckernate
    othertruckernate Bobtail Member
    18
    9
    Apr 12, 2013
    Cedar Rapids, IA
    As with all things, I would say it depends. If you have limited space to set up outside the hole, (I assume that was the question) slide them up. If the hole itself is tight (I know I know) like say closely spaced dock doors with a crooked white Volvo on one side, it may be safer to slide them back and eliminate swing
    379exhd and Diletantte Driver Thank this.
  7. Woodys
    Woodys Heavy Load Member
    774
    1,629
    Mar 16, 2010
    Tampa, FL
    You dirty dirty man.
    I know a majority of places will require tandems all the way back for safe loading/unloading purposes. But if you have the choice id put them forward.
  8. dptrucker
    dptrucker Road Train Member
    4,671
    3,180
    May 14, 2012
    adelanto,ca.
    you can always slide tandems all the way back once you get in the hole
  9. jgarner
    jgarner Light Load Member
    100
    43
    May 22, 2012
    Rockingham NC
    I always do this.
  10. .honeybadger.
    .honeybadger. Road Train Member
    1,059
    1,156
    Sep 30, 2012
    FL
    I will usually have them in the meat hole or farther forward when backing in somewhere and before I actually bump the dock. Will slide them to the rear if the place requires it. Ive been to plenty of places where I have to slide them back at the guard shack and then just go around the corner and slide them forward again to drop the trailer or bump a dock. Shoot, sometimes I just ask nicely to not have to slide them at thr gate and promise to ensure theyre all the way back before I disconnect! Never been an issue and it makes it so much easier to back.
  11. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Home Depot DC's require tandems back before entering the yard. It doesn't matter to me where the tandems are. As long as I got a good setup, I'll get it in the hole.
