Anyone use "Tandem Stoppers"
I spent almost an hour trying to get my tandems in the 11th hole,
I had no problem hitting the 10th or the 12th but not the 11th.....
I see they make something called "Tandem Stoppers"
Just wonder if they're worth the 30 bucks
and if they sell them at truck stops or only online ...
Tandem Stoppers
Discussion in 'Experienced Truckers' Advice' started by Southpaw7391, Apr 13, 2012.
Page 1 of 6
I use a crowbar. Just go easy. Works great without hurting anything as long as your easy on the clutch.
Ethanmoosc and Southpaw7391 Thank this. -
I usually have to do a small dance while chanting to the gods in order to hit a exact hole. Because only miracles can do that. (FOR TANDEMS, not perverted things like I thought after reading it again)
Southpaw7391 and allniter Thank this. -
They scale me at the shipper but you don't get to see the readout. All I knew was my gross was 78740.
When i got to the nearest scale 40 miles away, this was my weight.
11280-30,240-37,220=78,740
Second weigh after sliding tandems all the way back.
11,440-34,060-33,220=78,720
How I lost 20 lbs I will never know haha
Ethan -
that's 2 gallons of fuel...
we run a fixed 5th wheel and also have an air gauge on the dash for the drives.
At 60 psi, that's around 33-34K on the drives.
depending on how it rides, you slide the trailer.
It's getting to the point unless I am over 42K load, I don't even scale the loads.Last edited: Apr 14, 2012
DrtyDiesel Thanks this. -
if it's pulling bad, your trailer is heavier than the drives.
When it rides REALLY nice, you are lighter or at the same weight on the trailer compared to the drives.
at 42K and with 3/4 tanks, I am right at 77K gross. -
Kansas Thanks this.
Page 1 of 6
