Tandem or spread axle on new flatbed?
Discussion in 'Flatbed Trucking Forum' started by OldeSkool, Sep 27, 2021.
  1. OldeSkool
    OldeSkool Road Train Member
    1,641
    4,422
    Jul 17, 2018
    New Hampshire
    It looks like I’m going to be buying a flatbed trailer soon for hauling mostly lumber. I’m sure most loads I will be close to legal weight. Would i be better off with a spread or tandem axle? I’m going to be doing short haul so the thought of always trying to get my axle weight right makes me think spread, but i would prefer a tandem if I could keep from always having to hit a scale where i can get my axle weight set right every load.
    jamespmack Thanks this.
  3. bjrc
    bjrc Light Load Member
    81
    96
    Sep 14, 2018
    Spread axle rides smoother, easier to scale axle weights, but is harder to make tight turns forward or backward, really needs a dump valve. If you are only doing short hauls in tight areas might think about a tandem since you wont be crossing scales often. You could get the air weight gauges setup for truck and trailer, comes in handy.
  4. beastr123
    beastr123 Road Train Member
    2,802
    22,833
    Jan 2, 2014
    Moose Jaw SK CAN
    For mostly lumber a 48ft spread or a 48ft front sliding spread would be what I would choose.
    Why pay for and haul that extra 5ft of trailer when your primary haul will fit as well on a 48ft? It is more important to ensure that you have winches on both sides of the trailer and that you should have strap storage on both sides. Air gauges on both truck and trailer are a godsend and a dump valve pays for itself in tire life very quickly.
  5. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    If you get a spread, add a dump valve to the rear axle. It'll make your life a lot easier. For what you're doing though a tandem could work just as well and you'll probably be able to find one cheaper than a spread.
  6. shooter19802003
    5,654
    42,106
    Feb 8, 2010
    I vote a spread, because in my opinion it's more versatile. You might be buying it to haul lumber now, but you never know what the future holds.
  7. OldeSkool
    1,641
    4,422
    Jul 17, 2018
    New Hampshire
    You’re right. The load board is my backup plan.
  8. D.Tibbitt
    140,665
    Lumber they are going to load you to 80k every single time. A spread is the only way to go. Get trailer and truck gauges to make life easier
  9. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,561
    Mar 12, 2020
    Spread with a liftable axle
    beastr123 Thanks this.
  10. SamuraiTater
    SamuraiTater Light Load Member
    95
    254
    Aug 11, 2017
    Spread axles are for guys that can’t do math and can’t conceptionalize how to balance a load. ;)
    I prefer sliding tandems for two reasons :
    1. Even after the load has been placed on my deck, I still have the ability to manipulate weight. With a spread ( even though you have 6000 extra pounds back there to work with ), you are stuck with however it was placed on your deck by the loader.
    I ask two questions EVERY SINGLE TIME…. “What’s this going to weigh ?” and “How much of my deck will it take up ?” Sometimes you can’t get answers to those questions. Sometimes you get incorrect answers to those questions. Sometimes the components of the load vary in weight and the loader really doesn’t know how much each part weighs.
    If you’re pulling a spread you have no choice but to take the loaders word, place it where you THINK is best and hope his numbers were accurate. Give me the sliding tandem, I’m smart enough to have the loader place it where I’ll still have autonomy to work around his bad math.
    2. I like being able to skew the weight forward, then bring my tandems up and shorten my deck. The added maneuverability is advantageous.
  11. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Spread axel, my load, it is loaded the way I want it
