I just picked up a trailer from the shop, and when I got to the DC found that the tandem bar won't even try to move. Probably going to take it back, but is there anything it may be that I could fix? Tried to look it up but all info was for pins not retracting.
Tandem bar won't pull.
Discussion in 'Experienced Truckers' Advice' started by Riobard, Feb 28, 2019.
Used to have some pretty worn tandem pins on RR trailers. We used to bang on them with a hammer or would have to "center" the pins in the holes by pulling the johnny bar and move just an inch to take the pressure off the pins..
loudtom Thanks this. -
More than likely never been greased. A little grease makes for a nice slide
Grubby and bryan21384 Thank this. -
stillwurkin Thanks this.
With trying to beat the pins out maybe spraying them down good with some liquid wrench might help it go faster.
99% of the time for me, it is too much tension where the pins are in the holes on the rail. I set the trailer brakes and move forward or back all the way, then barely pull it the opposite way so that the pins are centered in the holes and not touching the rails at all. Try having someone pull the bar while you strike the pins with a hammer. The alternative is to have someone pull the bar while trying to slide the tandems by moving the truck, just be more careful doing it.
Next check the elbow part with the spring that's on the hinge and make sure the bar is attached to it properly. Usually when this is a problem, the bar pulls easily but the pins won't retract or retract enough. Check the pins to make sure they're still attached to the mechanism that joins them. I use a 2" ratchet strap from the elbow to the frame or other secure spot that doesn't slide.Grubby, Mooseontheloose, EuropeanTrucker and 1 other person Thank this. -
Took it back, something in the tandems themselves wasn't adjusted properly. Thanks for the help though.
Lepton1 Thanks this. -
Get a BFH. (big firkin' hammer)
