Tall Rubber vs Low Profile
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ramirezbrandonc, Apr 9, 2018.
  1. ramirezbrandonc
    ramirezbrandonc Bobtail Member
    26
    25
    Feb 1, 2018
    Santa Fe, NM
    I was wondering if any of you had any experience or knowledge that you could pass on to me regarding the pros and cons of having more or less sidewall.
    I have several older trucks that are running on older steel rims that I would like to change over to aluminum or another alloy type of rim to save on overall weight and fuel mileage. I have been wondering if I would be better off running low pro tires or tall rubber for several applications ranging from a dump truck to highway trucks running flatbeds and drop decks.
    I have always preferred a tall rim and a tall sidewall for the off-road benefits that I perceive them to have despite the fact that the majority of my work is highway. My dad has always preferred a low profile tire.
    Has anyone switched from one to the other and noticed any difference on fuel mileage, tire life, brake life, turning radius or limitations, or performance on and off road? Any other changes you can think of that I have not addressed please feel free to address.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Low profile offers less rolling resistance less weight better pulling power easier to find tires on the road because everyone uses them it's a win win. But for off road work you may need to stay with the tall rubber. Low profile also gives better fuel economy
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Going to small rubber you'll gain pulling power but run at a higher rpm thus lose some mpg.
    ramirezbrandonc and Heavyd Thank this.
  5. I glide 47
    1,426
    1,523
    Jun 3, 2017
    Lower rolling resistance will over come the higher rpm and thus better fuel economy. I know I gust opened the can of worms but that' my two cents
    ramirezbrandonc Thanks this.
  6. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    24.5 low pro and 11r22.5 have the same diameter therefore same rpms
  7. I glide 47
    1,426
    1,523
    Jun 3, 2017
    You win the cigar. Correct but I was referrng to 22.5 low pro
  8. ramirezbrandonc
    26
    25
    Feb 1, 2018
    Santa Fe, NM
    My biggest question was if the higher RPM caused by a change in diameter would be offset by a change in rolling resistance. I think the answer is to keep 24.5s with high rubber on my off road trucks and to go up from 22.5 to 24.5 and use low profile tires for my highway trucks in the future. Thank you for the help.
    QuietStorm Thanks this.
  9. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Ya can argue fuel mileage all you want but..... 24.5 look better.
    Cat sdp and ramirezbrandonc Thank this.
  10. I glide 47
    1,426
    1,523
    Jun 3, 2017
  11. I glide 47
    1,426
    1,523
    Jun 3, 2017
    They do look better I agree with you ps. That don't happen very often
